Projects Bobbed VS Stock Coupe Rear Fenders
Discussion in 'Traditional Hot Rods' started by Mark Jenny, Jan 9, 2015.
  1. DrJ
    DrJ
    BigDrag, is that part of a '59 Pontiac hood used to fill the roof?
  2. BigDrag
    BigDrag
    from Milwaukee
    Sounds like Drew took out 5".....I'm learning everyday. The roof is filled with a 1959 Pontiac hood turned backwards, the dash and engine are also 59 Pontiac. Tail lights are 61 -63 Mercury Comet. Thanks about the car but Drew and Mike deserve all of the credit.
  3. Mark Jenny
    Mark Jenny
    Well your still fortunate to own it,,,shes a beauty!!..would love to see more pics
  4. Fenders
    Fenders
    Seven inch section out of mine....
    But for fiberglas flthd31 did it right. Seam will eventually show if its sectioned.
  5. BigDrag
    BigDrag
    from Milwaukee
    Here are a few more pictures of the coupe. Last spring the Meteor fuel injectors developed leaks so I'm putting Rochesters on it till I can figure out a fix. Dave Martinez did the interior. Drew at Suicide Axle built the car. Mike Zenor was the OG owner and driving force behind the build. DSC_0376.JPG DSC_0629.jpg DSC_0031.JPG
  6. Mark Jenny
    Mark Jenny
    That sir is one Killer machine!!!
  7. 40ford
    40ford
    from Duluth, GA
  8. 40ford
    40ford
    from Duluth, GA
    Don's A coupe rear fenders bobbed 5 inches
  9. Here's my bobbed fenders...
  10. Mark Jenny
    Mark Jenny
    Everyone of these post have been a big help. Thanks guys for all the feedback and pics!!..I need new front fenders anyway, so I may just get a full set of steel fenders so I can section the rears....it's more of a factory look, so I'll see if budget allows...I hate that word.."budget"....yuck!!
  11. Rich B.
    Rich B.
    from Portage,IN
  12. I kinda like the fenders stock but to my way of thinking the rear of the model A looks like the fenders are too long when lowered.
    I prefer the deuce gas tank like the coupe in the above photo (Rich B) or the use of a filler panel like what is on Jim's coupe. HRP 134930_4551336658266_84812231_o.jpg
  13. Budget is just telling your money where to go instead of wondering where it went.
  14. The word BUDGET when used with the word hot rod is a OXYMORON. :D HRP
  15. Sure seems that way.
    Doing what you can with what you have is the essence of what we do and hot rods is a result. Isn't knowing what you have (budget) a primary objective before you can start doing with intent of finishing?
  16. Mark Jenny
    Mark Jenny
    I like that filler panel...it makes the fenders look balanced
  17. ago
    ago
    from pgh. pa.
    My 32 with bobbed fiberglass fenders with lip molded back on. IMG_9963.JPG IMG_0082.JPG
    40fordtudor likes this.
  18. Kan Kustom
    Kan Kustom
  19. chrisntx
    chrisntx
    from Texas .
    save the pieces you cut off so the next guy can fix them
  20. joel
    joel
    X2, definitely section and I would add the rolled pan with the fender tips about 2 in below the bottom of the pan.
  21. Boatmark
    Boatmark
    I'm actually in the boat business, so I have been doing the glass thing forever. Done right, sectioning a fiberglass fender will be stronger than you think. It will never be steel, but if glass is what you have, I wouldn't be afraid to section them. The trick is to move the join line as far up into the fender as you can without disturbing the arch. This will give you a long enough "tail" section to layer the joint over an extended area - using multiple layers of glass, each spreading further out on the feathered joint. Most people will try to make the "tail" as short as possible, and then there isn't enough area to layer the joint.
    Let me know if you need some detail, or depending on where in the country you are, I can recommend a glass shop that specialize in fixing crash boats - no biggie for them.
  22. Mark Jenny
    Mark Jenny
    This is interesting info Boatmark...I'm in Carthage MO...considered the 4 state area I'm bording kansas,oklahoma,and arkasas...
  23. Donut Dave
    Donut Dave
    Before and after.... Before Primer (1280 x 960).jpg 1928 Progress Photos 090 (1280 x 960).jpg
    Baron likes this.
  24. Mark Jenny
    Mark Jenny
  25. indyjps
    indyjps
