I have a 1959 Buick Le Sabre. I like to convert from a generator to an alternator. I bought an alternator bracket from a 1964 Buick Riviera and a new Remy mid-1980s GM B-body (Electra, Delta 88, etc) with the Olds 307 motor used a 78 amp 12SI alternator.( voltage regulator mounted internally ). Does anybody knows how to wire the new alternator on a push gas to start 1959 Buick ? Is there a wiring diagram ? Thanks for any help
Why?? rebuild it and drive the wheels off of it. Nothing wrong with a generator. No better performance No better gas mileage....Why, One wire alternators are for pussies that are afraid all the time. Be a man build a generator
Most generator problems stem from worn brushes. Rebuild your generator; it's very similar to a starter and parts can be had from your local NAPA. With a good solid state voltage regulator, a generator is great!
Ditto, as long as the brushes and regulator are in good condition there is nothing wrong with generators at all.
Thanks so much for the info BJR. For my other 3 friends. I know that a generator will be fine to, if you use the car for weekend drives. I you the car for business. (wedding ,wine tours etc.) I rebuild the generator ,but with slow driving, Radio, Air etc the generator will not work good enough. One other problem is ,that in Canada you can't go to Nappa and buy parts for old Buick’s .Every thing has to be shipped from the USA. Shipping is higher than the part. I will keep the generator
Basically the vacuum switch on the carburetor is grounded through the voltage regulator and when the engine is running will not complete the ground circuit to prevent engaging the starter. I just wired around that to ground and never had a problem since the vacuum switch also cuts off when the engine is running. If the vacuum switch ever got stuck it might cause a problem and that was what the regulated ground was to prevent.
I guess it depends. I drove a litte 1958 Holden to school and then tech college everyday for close to 3 years. The only time I ever had issues with the generator was when the brushes wore out, and believe me, the radio was always on and the aircon was cranked (especially during the summer, darn Aussie climate).
