1930 Ford Sport Cp HighBoy This is a project is a roller to be assembled, about 95% complete.Small rust in Cowl panel, other rust has been repaired or replaced. Door and windshield have been replaced. 59AB Flathead. Rebuilt before I purchased. Has early Navarro 3 x 2 manifold, 3 - 97s Carbs-rebuilt by Uncle Max of the HAMB. Rebuilt fuel pump, Edmunds alum heads. Ferrari fuel filter with a adjustable pressure regulator. C4 Trans w adaptor, Mustang floor shifter. Open drive differential adaptor, 1930 A Spring on top of rear axel. New Speedway front suspension. 4 wheel hydraulic brakes, stock A Frame, modified by moving front, cross member 2 inches forward, rear cross member Zed about 4 inches, F -1 steering box-modified with adaptor- Radiator with thermal static control, license and titled in Az- much more! Speedway Parts New 916-39516 Front Suspension 916-33006 Front U Bolt Kit 916-3197 Brake Pedal Mount 910-11005 Air Filter x 3 # 560-62713 Carb Progressive Linkage # 910-13601 Headers # 910-23101 Transmission Cooler 928-580-2491 $8500 or Make Offer Dave
