Projects 54 4dr BelAir build!!!
Discussion in 'The Hokey Ass Message Board' started by Jbuhl1954, Sep 21, 2013.
  1. freiertpc
    freiertpc
    sorry did not mean it that way bro, Was just trying share some advice . Let me know if you need extra parts I have miscellaneous odds and ends for the 53-54 4 doors
    take care
  2. Jbuhl1954
    Jbuhl1954
    Alright so I did a little tinkering while the wifey is feeling better!! Just decon the motor to get ready to pull out and rebuild!!! Can't wait to get the MII front end, so I can get some real work done!! Lol!!
  3. Jbuhl1954
    Jbuhl1954
    ImageUploadedByH.A.M.B.1395097109.081067.jpg ImageUploadedByH.A.M.B.1395097127.921132.jpg ImageUploadedByH.A.M.B.1395097149.534621.jpg
  4. Jbuhl1954
    Jbuhl1954
    Oh man I got my MII setup!! Can't wait to get started on it!! ImageUploadedByH.A.M.B.1397143172.890565.jpg
    Gonna sit in the dirt!!!
    Thanks to Fulltilt street rods for the quick service!!!!!
  5. Jbuhl1954
    Jbuhl1954
    So I got some time to work on the car a little bit this week.. Pulled car out into sun and yanked the motor and trans... ImageUploadedByH.A.M.B.1398045402.035807.jpg
    Stripped the front end off and rolled her into the garage... ImageUploadedByH.A.M.B.1398045808.283490.jpg ImageUploadedByH.A.M.B.1398045932.346122.jpg
    Got her up on stands and unbolted and rolled the crossmember and front end out from under her... MII coming next!!! ImageUploadedByH.A.M.B.1398046337.605570.jpg ImageUploadedByH.A.M.B.1398046369.585793.jpg
  6. Jbuhl1954
    Jbuhl1954
    Ok so it's been awile but the wife is doing great so I can get back to work on Merlene!!! Got the MII done!! ImageUploadedByH.A.M.B.1413411171.754888.jpg ImageUploadedByH.A.M.B.1413411229.630049.jpg ImageUploadedByH.A.M.B.1413411288.117358.jpg ImageUploadedByH.A.M.B.1413411371.272049.jpg ImageUploadedByH.A.M.B.1413411456.784332.jpg
    While the front end was off I shaved the firewall a bit also!! ImageUploadedByH.A.M.B.1413411621.983559.jpg
    Got motor and tranny mounted and mounts made!! ImageUploadedByH.A.M.B.1413411789.506401.jpg ImageUploadedByH.A.M.B.1413411826.017600.jpg ImageUploadedByH.A.M.B.1413411853.082336.jpg ImageUploadedByH.A.M.B.1413411924.389964.jpg ImageUploadedByH.A.M.B.1413411968.518462.jpg
  7. Rynos63
    Rynos63
  8. mcnally351
    mcnally351
    from boston
  9. Glad your wifes doing better.Your really going to town on that baby .I like it.Bruce.
  10. Jbuhl1954
    Jbuhl1954
    Thanks Bruce!!
  11. Jbuhl1954
    Jbuhl1954
    Here is some more work I got done in the past few weeks!! Started tubbing the rear!! ImageUploadedByH.A.M.B.1413496636.804991.jpg ImageUploadedByH.A.M.B.1413496678.685652.jpg ImageUploadedByH.A.M.B.1413496857.420804.jpg ImageUploadedByH.A.M.B.1413496928.641813.jpg
    Shortened the steering column..
    ImageUploadedByH.A.M.B.1413497036.170202.jpg ImageUploadedByH.A.M.B.1413497089.585420.jpg
    Then my buddy bout a house and it has a big shop with it so a put the car together for the trip!!
    ImageUploadedByH.A.M.B.1413497173.481025.jpg ImageUploadedByH.A.M.B.1413497201.021482.jpg ImageUploadedByH.A.M.B.1413497246.302496.jpg ImageUploadedByH.A.M.B.1413497275.107285.jpg
    But back to work it is just with lots of room now!! Finishing the rear tubbing and seat pan and notch cover.. ImageUploadedByH.A.M.B.1413497378.683739.jpg ImageUploadedByH.A.M.B.1413497417.863753.jpg ImageUploadedByH.A.M.B.1413497461.315879.jpg ImageUploadedByH.A.M.B.1413497545.340311.jpg ImageUploadedByH.A.M.B.1413497590.757930.jpg ImageUploadedByH.A.M.B.1413497668.114660.jpg ImageUploadedByH.A.M.B.1413497713.749141.jpg
    And then put a seat from an '87 short wide and it fit great!! A few mods and it's good to go!!
    ImageUploadedByH.A.M.B.1413497800.861291.jpg ImageUploadedByH.A.M.B.1413497828.950740.jpg
    Next thing is to mount gas tank and start on trunk floor!!
  12. StefanS
    StefanS
    from Maryland
    Hows the build going? I'm doing a notch this winter on my '54 four door. I'm curious as to how much the notch itself interfered with the rear seat back bracing? I'm using a 2 piece driveshaft and the plan is to only cut out sheet metal in the wheelwells
  13. Jbuhl1954
    Jbuhl1954
    Stefan it is going well!! Thank you!! Um if you use a gambino notch it lines up with the back seat so you don't have to cut out seat is what people say!! I used a different notch so I had to scrape my old seat back!!
  14. Jbuhl1954
    Jbuhl1954
    So I have been M.i.a. On the hamb for a bit but here is some progress!! Pulled body off to finish up gas tank mounting, got tank mounted and put body back on to finish trunk floor and wheel tubs!! ImageUploadedByH.A.M.B.1424794940.492899.jpg ImageUploadedByH.A.M.B.1424795017.949392.jpg ImageUploadedByH.A.M.B.1424795059.019075.jpg ImageUploadedByH.A.M.B.1424795141.892636.jpg
    Put body back on to finish the trans tunnel and trunk skin!! ImageUploadedByH.A.M.B.1424795414.901033.jpg ImageUploadedByH.A.M.B.1424795441.322496.jpg ImageUploadedByH.A.M.B.1424795550.744064.jpg ImageUploadedByH.A.M.B.1424795713.940999.jpg ImageUploadedByH.A.M.B.1424795806.348881.jpg ImageUploadedByH.A.M.B.1424795854.986550.jpg
    Fixed the rot in the passenger kick panel!! The door hinge and all was basically gone!! ImageUploadedByH.A.M.B.1424796120.759475.jpg ImageUploadedByH.A.M.B.1424796164.562619.jpg ImageUploadedByH.A.M.B.1424796651.807684.jpg ImageUploadedByH.A.M.B.1424796683.712803.jpg ImageUploadedByH.A.M.B.1424796726.163932.jpg
    Well then decided to put a 57 Chevy front bumper on my 54
    ImageUploadedByH.A.M.B.1424796810.971315.jpg ImageUploadedByH.A.M.B.1424796865.947712.jpg ImageUploadedByH.A.M.B.1424796897.078811.jpg ImageUploadedByH.A.M.B.1424796959.400576.jpg ImageUploadedByH.A.M.B.1424797086.728263.jpg ImageUploadedByH.A.M.B.1424797217.629932.jpg ImageUploadedByH.A.M.B.1424797236.158039.jpg ImageUploadedByH.A.M.B.1424797265.143344.jpg ImageUploadedByH.A.M.B.1424797318.367419.jpg ImageUploadedByH.A.M.B.1424797351.969424.jpg
    Back with more later!!
    flux capacitor and Thrift-King like this.
  15. Rynos63
    Rynos63
    That bumper looks killer...
    Jbuhl1954 likes this.
  16. Jbuhl1954
    Jbuhl1954
    Thanks man!! I appreciate it
  17. Buddy Palumbo
    Buddy Palumbo
    Looks great
  18. Thrift-King
    Thrift-King
    Dude.... that is badass! Me = jealous of you skills and resources!
  19. Nice work. I wouldn't have imagined the '57 would look as good as it turned out.
  20. Jbuhl1954
    Jbuhl1954
    Thanks guys!! It was fun doing for sure!! Really matched pretty well and then just trimmed her in!! But ya I appreciate the positive feedback!!!
  21. Baumi
    Baumi
    the 57 bumper is a great idea, never seen that before but I really like it!
  22. Jbuhl1954
    Jbuhl1954
    Thanks baumi!! I appreciate it!!
    Baumi likes this.
  23. Jbuhl1954
    Jbuhl1954
    Got a little more work done!! Got the 2002 Chevy camaro brake booster/master mounted and the pedal cut to fit!! The square tubing is bracing from the firewall to the dash.. I made them adjustable to be able to take all the flex out of the firewall!!
    ImageUploadedByH.A.M.B.1426955931.913231.jpg ImageUploadedByH.A.M.B.1426955982.079218.jpg ImageUploadedByH.A.M.B.1426956012.447576.jpg ImageUploadedByH.A.M.B.1426956073.820059.jpg ImageUploadedByH.A.M.B.1426956111.389342.jpg
    Then I decided I needed to French my headlights!!
    ImageUploadedByH.A.M.B.1426956236.599690.jpg ImageUploadedByH.A.M.B.1426956265.869396.jpg
    Pretty pumped with how the car is shaping up!!!
  24. Jbuhl1954
    Jbuhl1954
    Well lots going on lately, went swap meet and scored a 62-63 belair steering wheel, some trim and front and rear 1948 Buick bumpers.. Decided to use the front bumper as the rear bumper on my 54'
    ImageUploadedByH.A.M.B.1428096128.213770.jpg ImageUploadedByH.A.M.B.1428096229.732765.jpg
    Then started my front wheel tubs, got them tacked in
    [ ImageUploadedByH.A.M.B.1428096549.145064.jpg ATTACH=full]2873642[/ATTACH] ImageUploadedByH.A.M.B.1428096310.889257.jpg ImageUploadedByH.A.M.B.1428096364.895870.jpg ImageUploadedByH.A.M.B.1428096390.062868.jpg ImageUploadedByH.A.M.B.1428096421.298537.jpg ImageUploadedByH.A.M.B.1428096449.685569.jpg ImageUploadedByH.A.M.B.1428096505.109062.jpg ImageUploadedByH.A.M.B.1428096522.890501.jpg
  25. mcnally351
    mcnally351
    from boston
    Wow very creative
  26. Jbuhl1954
    Jbuhl1954
    Alright put a 1948 Buick front bumper on the rear of the '54!! I flipped it upside down, so I had to rework the horns to fit!! I think it adds a nice touch to the rear!! ImageUploadedByH.A.M.B.1428612101.354509.jpg ImageUploadedByH.A.M.B.1428612116.374841.jpg ImageUploadedByH.A.M.B.1428612140.739506.jpg ImageUploadedByH.A.M.B.1428612166.660073.jpg ImageUploadedByH.A.M.B.1428612177.809493.jpg ImageUploadedByH.A.M.B.1428612224.213718.jpg
  27. Jbuhl1954
    Jbuhl1954
    The transformation of Ol Merlene is really pleasing me!! ImageUploadedByH.A.M.B.1428612282.335144.jpg ImageUploadedByH.A.M.B.1428612300.319845.jpg
  28. Awesome work!! Jim
  29. verde742
    verde742
    NICE you got imagination !!! skills !!!!
  30. Jbuhl1954
    Jbuhl1954
    Thanks guys I appreciate the positive feedback!!
