Caddy Engine Casting Numbers
Discussion in 'The Hokey Ass Message Board' started by Slick50, Sep 11, 2009.
  1. Hi all,
    Here is some Caddy casting number info I came across a while ago, while I was trying to decipher my engine numbers. It's by far not a complete list, so if you can add to it feel free to do so, or send me the info and I will include it. This may be better placed elsewhere on the board, but I wanted to put it here so it would be seen by anyone who might find it useful.
    The info came from a site called "Swap Meet", but I've never been bright enough to find it after the first time I stumbled upon it. It is accurate for my engine numbers, but further than that I do not know so use it as you see fit. I have it as a word document if needed.
    Cadillac Casting Numbers
    Block
    Cast number Year Displacement
    1464819 57 365
    1467267 58 365
    1469230 59-63 390
    1473257 59-62 390
    1473267 63 390
    Intake Manifold
    1455104 49 331
    1456741 50-51 331
    1463414 52-55 331
    1464176 56 365
    1465061 57 365
    1469889 58 365 (3x2)
    1472225 59-60 390 (3x2)
    1486425 68-69 472
    Head
    1465406 (right) 57 365
    1465431 (left) 57 365
    1473449 (right) 58-63 390
    1468025 (left) 58-63 390
    Exhaust Manifold
    1453961 (right) 49-51 331
    1453754 (left)
    1463961 (right) 52-55 331
    1461495 (left)
    1462987 (right) 56 365
    1464110 (left)
    1464237 (right) 57 365
    1464110 (left)
    1469298 (right) 58 365
    1475463 (left)
    1475390 (Right) 59-62 390
    1475463 (left)
    1477980 (right) 63-64 390
    1475463 (left)
    1481668 (right) 65 (Fleetwood) 429
    1475463 (left)
    1483915 (right) 65-67 429
    1482752 (left)
    1485556 (right) 67 (Eldorado) 429
    1485555 (left)
    1486442 (right) 68-69 472
    1486383 (left)
    1485750 (right) 68 472
    1485749 (left)
    1495095 (right) 70-74 472/500
    1486383 (left)
    1486442 (right) 75 500
    1486383 (left)
  2. Half-Fast Motors
    Half-Fast Motors
    Thanks Ken. Just bought a Caddy V-8 & not sure if it's a 331 or later motor. This helps.
  3. Smokey2
    Smokey2
    Tryin' to I.D. What I Think Is 365 c.i. Caddy?
    Block 12551364 ??
    Head 2561878 ??
    Crank 12552215
    ___________________________________________
    :eek:
    "My Wife ran off with my BEST FRIEND !
    An, I sure Do MISS HIM!" Smoke'
  4. kustomrf
    kustomrf
    nice mine is 59-63 390 it came out of a 59
    thanks slick50
  5. Pete
    Pete
    I’m having trouble figuring out which motor I have.
    Block casting number is 1461476
    Stamped into the bell housing (driver side)
    Is 4V5269
    Stamped into the front left deck is 556206628
    And ideas??
    Pete
  6. H380
    H380
    from Louisiana
    I get 1461476 as a 1955 Olds 331 block. Not Caddy.
  7. Pete
    Pete
    Haha....it’s def a caddy
    I measured the bore, it’s a 331
  8. H380
    H380
    from Louisiana
    On all the lists I have saved. Has it as an Olds. Maybe bad info. One PDF from a google search has this.
    Cadillac
    331 54-55 #1461476 w/o integral bell housing
  9. Pete
    Pete
    That’s exactly what it is, unfortunately it takes the Uber hard to find bellhousing
  10. mgtstumpy
    mgtstumpy
    • Serial numbers and engine numbers were the same again.
    • They appeared
      • on a boss on the front right hand face of the engine block;
      • on the lubrication plate on the left front door pillar (1953-1957)
      • and on the right frame side member behind the motor support.
    • The first pair of symbols were "55" to designate the model year.
    • The next two symbols indicated series as follows:
      • "62" = Series 62 including Eldorado Specials;
      • "60" = Series 60 Fleetwood;
      • "70" = Series 70 Eldorado Brougham; and
      • "75" = Series 75 Fleetwood
    • The immediately following numbers, beginning at 00000 for each series, indicated the production sequence in consecutive order.
    • Ending numbers were the same for all series since the engines were installed in mixed production fashion.
    1955 YOM, 62 series engine, http://forums.cadillaclasalleclub.org/index.php?topic=119266.0
  11. TheCarcheologist
    TheCarcheologist
    Hi guys. I was a member of the H.A.M.B. for a long time, but that was years ago. "Life" happened, a little boy was born, the career changed... Yadda yadda yadda. So anyhooo, stumbled upon this thread while researching something I found on a '58 Caddy thats been eating away at me for a few weeks now. It's nothing outrageous or anything, just... odd. I pretty much determined it was a 365 based on the 1465061 casting number on the intake. It's just a standard 4V intake as far as I can tell, but EVERY SINGLE OTHER INTAKE I've found anywhere online with this casting number is followed by a "-1", whereas the one I put eyes on a few weeks back was followed by a "-2". I've been unable to find another with this casting number followed by a -2. Any idea what the dash-digit means, or why this one isn't like all the other kids? Thanks in advance, and I'm hoping to rejoin the little family of guys that build go-fast if you'll have me!
