Hello I just recently got a 53 buick 4 door looking to lower it is there and stock springs out of newer vehicles I might find at wrecking yard that will work thanks for your time
I'm not sure about the front springs but the rear can't be cut because they narrow down were they attach. Some people remove the plate the spring sits on it the front and put a spacer between it and the control arm but that won't get you but a inch.
