Flathead v8 60 Eddie Meyers heads nice shape for originals. Outside fins are nice not broken or cut, they could use a good blasting and surfacing from sitting around . The only area I have seen of and issue is one spark plug hole was repaired at one time and looks to have had the valve contact it lightly, heads can be run as is if desired. PM if you have any questions!
Its been brought to my attention that a small crack is visible by the plug hole in the photo posted, the crack is their and is not severe but will need attention. 450.00 will be the new price O.B.O sorry folks for not seeing it sooner and thanks for the heads up.
