Is a halibrand quick change rearend with ten bolts on each side good for an early ford or is it to big. ? and is $350 A good price with out tubes? It has the gears.Thanks Pete
and that's a really good price. model A and V8 are slightly different, V8 being larger and having a straddle bearing inside. model A's built for midgets used 1" wide gears,all others use 1 3/8"
is 350 a good price? what planet are you liveng on? the 10 bolt V8 qc case width is 3 7/8" i'll give you $1,000 for it if it is a V8 qc. paypal. send pictures. [email protected]
