My Av8
Discussion in 'Traditional Hot Rods' started by 67cst, May 24, 2014.
  1. 67cst
    67cst
    Here are a couple recent pictures of my '31. I will share more if you guys want. It sure feels good to finally drive it. I still have a few loose ends to deal with but mainly cosmetic stuff.
    ImageUploadedByH.A.M.B.1400948150.125160.jpg ImageUploadedByH.A.M.B.1400948219.401065.jpg ImageUploadedByH.A.M.B.1400948417.623100.jpg
    Ryan likes this.
  2. Very nice!
    Go drive the wheels off it!
  3. Nice stance and gauges.I like your wiring under the seat.
  4. Jethro
    Jethro
    Very nice! Where did you get the bezels for those gauges? They are trick!
  5. like the electrical under the seat.
  6. RainierHooker
    RainierHooker
    from Tacoma, WA
    Very nice, it's always nice when you break out if the tunnel, and actually drive it.
    That seems like an awful lot of circuitry, accessories? Sure looks pretty under the seat.
    Posted using my Lil' Orphan Annie Secret Society Decoder Pin
  7. brady1929
    brady1929
  8. heminh2o
    heminh2o
    from Tulare, CA
    Dig the car. What is the switch box just in front of the seat for? Ignition and start?
    Never finished
  9. 67cst
    67cst
    Thanks guys....
    The wiring looks busy and it is. I have relays for fuel pump, low beam, high beam and horn. Also I have an additional 4 relays (87a's) wired so that my tail lights which are dual filament can signal/stop/tail. It was Definitely a learning curve but well worth it.
  10. kyvetteman
    kyvetteman
    Very cool! The stance is killer. The wiring reminds me of my '29 AV12's, which I'm close to firing for the first time. Enjoy your coupe![​IMG]
  11. 67cst
    67cst
    Looks good ky,
    The switch box controls signals, hazards, horn, start button and hi/low's and fuel pump. I didn't want to run more wire to the dash then I needed.
  12. kyvetteman
    kyvetteman
    Thanks. Yours is very well done. Do you plan to put anything between the electricals and the bottom of the seat? I'm a bit concerned that the seat springs might bottom out on mine. I'm a bit of a lard ass. :oops:
  13. Ryan
    Ryan
    ADMINISTRATOR
    That's a bitchin car.
  14. dellyjonut
    dellyjonut
    from St. louis
    No we don't like bitchin traditional Av8s on this site. Sorry. Kidding! Please share more, that thing is pretty perfect.
  15. J. A. Miller
    J. A. Miller
    from Central NY
    Sweet ride! Please tell us more about the guages.
  16. ydopen
    ydopen
    Electrics under seat are a good idea. Saves a lot of under dash time. Sure is a nice car.
    John
    wino01 likes this.
  17. 4wd1936
    4wd1936
    from NY
    Wow! One of the nicest pieces of work I have seen. You can sure be proud of that car.
  18. Hotrodmyk
    Hotrodmyk
    1. Northwest HAMBers
    Very cool car and sano wiring under seat. Well done ! Enjoy now.
  19. 67cst
    67cst
    Thanks for the kind words fellas.
    Here are some more details. I'll try not to make this too long winded.
    The project started about 3+ years ago when a friend of a friend had a set of old boxed 32 rails. It took a bit of time but I finally got them home along with a glass deuce rad shell and a p/u box. ImageUploadedByH.A.M.B.1400994140.276036.jpg
    Shortly after getting these parts I came across a '33 cab which I bought but didn't end up keeping very long. I ended up selling it with the box and the hunt began for a coupe. My dad found the '31 on Craigslist and that next weekend we made a 19 hour round trip the WA / Oregon border to get the car. It was a long drive but well worth it for such a straight car.
    The frame rails were worth saving but the rear horns were cut off. I ended up grafting some 2x4" tube to the rails so I could hang my leaf behind the rear. ImageUploadedByH.A.M.B.1400995205.422402.jpg ImageUploadedByH.A.M.B.1400995404.157168.jpg ImageUploadedByH.A.M.B.1400995435.059052.jpg
  20. 67cst
    67cst
    Ill post more in the morning.
  21. waxhead
    waxhead
    from West Oz
    Very nice, keen to see more pics
  22. peter schmidt
    peter schmidt
    from maryland
    Wow very nice. Any chance you saved those rear frame horns?
  23. chiro
    chiro
    How did you handle the firewall? Your floor looks very much stock-like, especially the toe panel so I was wondering what you did to the firewall to clear the heads on the flatty.
    Really nice looking rod, bro. Just love it. Also, those gauge bezels are pretty trick.
    Andy
  24. Bitchin' coupe man! What year rear end and leaf is that? Also what size tires are you running?
    thanks
  25. 67cst
    67cst
    The gauges are stewart Warner's. Most of them are nos off eBay as well as the bezels. A guy named mr dash sells them.
    I don't have the stock rear horns, when I got the 2 rails they were boxed but the previous owner had bucked off the rear horns directly over the rear axle centerline.
    When I welded the the model A front crossmember into the frame I cheated it forward an inch and a half. I didn't want to cut the stock firewall nor did I want to mess with the floor. That extra 1.5" gave me about 3/4" on the front end for fan clearance so I can swap belts. Ill post a bunch more pictures here in the next while and try to awnser anymore questions i may have forgotten.
  26. 67cst
    67cst
    Ok guys. Got it outside in the light for some more pictures. Here are some shots of firewall and fan clearance... ImageUploadedByH.A.M.B.1401038192.632608.jpg
    As for front end:
    Cool old chromed round back spindles I found with brakes that a guy was getting rid of for disc brakes.
    Had to put a dip in my drag link to clear the pulley. It wasn't a real issue but if I hit anything hard I didn't want the two making contact. ImageUploadedByH.A.M.B.1401038633.548023.jpg
    The wood inside was pretty much shot. I bought a cheap bandsaw locally and used the original wood as
    Templates and made new wood out of a big old rock hard slab or fir. Seemed to work out pretty great. I cleaned up and used all the original fasteners, I'm a few short here and there but I'll find more. ImageUploadedByH.A.M.B.1401038874.680007.jpg ImageUploadedByH.A.M.B.1401038969.004430.jpg
  27. 67cst
    67cst
    I put a "tanks" fuel tank in the trunk. I built a frame to get it up off the floor a bit so I had a spot underneath for a tools etc. ImageUploadedByH.A.M.B.1401039189.991055.jpg ImageUploadedByH.A.M.B.1401039239.591599.jpg I wanted to keep the stock bowl on the firewall so from the pump I ran it underneath the car then inside the cab to the regulator. It was a bit of extra work but that glass bowl was too cool to not use.
  28. Bader2
    Bader2
    Where'd you get the plug wires and ends from? Nice job on the tubing, cars lookin good!
    I know how much work you've put in!
  29. Super Streak
    Super Streak
    from Florida
    You've done a great job on the coupe. Every thing about it is cool, good luck with it !
  30. Extremely well executed car. I love it.
