I need help I have a 1957 y block with a 48 ford 3 speed behind it what do I need to replace it with an s10 T5 5speed trany . any help or pics would be appreciated. 3 speed just is not enough gears. Thanks
I need help I have a 1957 y block with a 63 ford 3 speed behind it what do I need to replace it with an s10 T5 5speed trany . any help or pics would be appreciated. 3 speed just is not enough gears. Thanks
check out this thread for an option...some good pics http://www.jalopyjournal.com/forum/threads/project-t-riffic-26-model-t-sedan.845204/ this is how I did it...may be better ways but this worked for me.
I am told that an early ford 5 speed should bolt right up and all thet is needed is to drill one hole any one know if this is true
Why not stay traditional and use a 57 Ford 3spd with overdrive, Borg Warner T-85 that will bolt right in......
Check this out"...... http://www.jalopyjournal.com/forum/threads/y-block-to-t5.933964/ What car is this y-block early three speed in?
Don't forget the s10 t5 has a longer input than a standard Chevy trans! Some early ford t5 s will bolt up some have a longer input like the Chevy ones, not sure which though.
