Wiring a running Engine Stand???
Discussion in 'The Hokey Ass Message Board' started by Clik, Nov 4, 2013.
  1. Clik
    Clik
    Anyone know where I can get a simple wiring diagram for a running engine stand?
    Small Block Chev - Single Wire Alternator - MSD.
  2. Rickybop
    Rickybop
  3. henryj1951
    henryj1951
    from USA
  4. Now thats pretty damm simple!
  5. Kiwi 4d
    Kiwi 4d
    Perfect, have done a few and this is it. Unless of course you feel the need to run a generator or alternator into the mix to keep things charged. A one wire is just that , one wire to the batt. Positive.
  6. Mr48chev
    There isn't much need to run a generator or alternator unless you plan to run the engine for hours on end. Having one mounted serves as the belt adjustment for the water pump in most cases though.
    Actually a push button for the starter and a toggle switch for the ignition will work fine in place of the key switch unless one just wants a key switch.
  7. Clik
    Clik
    The present engine I have to put on the stand has a single wire alternator and a push button/toggle is fine with me.
