Hot Rods Who overseas owns this '32 5w?
Discussion in 'The Hokey Ass Message Board' started by 3wLarry, Sep 26, 2015.
  1. 3wLarry
    3wLarry
    from Owasso, Ok
    Got a PM from a guy that wants contact info on this 5w...anyone help with who owns it overseas?
    kidcampbell71, Moriarity and Cusco like this.
  2. 117harv
    117harv
    Nice coupe, looks like the springs are worn out. :)
  3. 3wLarry
    3wLarry
    from Owasso, Ok
    I vaguely remember it being from Sweden, Switzerland, Denmark?
  4. tmfcracing
    tmfcracing
    from Sweden
    3wLarry likes this.
  5. 3wLarry
    3wLarry
    from Owasso, Ok
    thankya kindly
  6. I thought maybe the Hieroglyphics on the windshield meant FFinland.
    tmfcracing likes this.
  7. A Boner
    A Boner
    Steering wheel probably on same side as windshield wiper, if that helps.
    volvobrynk likes this.
  8. Eric1967
    Eric1967
    from Union, Mo
    Thanks for the help guys. I am building a 5 window & trying to research to get a game plan. I contacted Larry from a picture of this car that he posted in the wire wheel thread. I love the stance. I want the car to be drivable but as low as possible. I am new to building this style of car. I was able to purchase a nice Henry steel body from a family friend a few weeks ago. My mind has been racing ever since.
    Thanks
    Eric Earney
  9. Bigbangtheory
    Bigbangtheory
    from ohio
    Hey Eric, how about some pics of what you have? I think the 5 window in the pic above is so cool.
  10. Eric1967
    Eric1967
    from Union, Mo
    Here is a quick pic of the car when I went to pic it up. I have all the fenders & running boards. It has 53 Merc Flathead. The engine has been rebuilt but sat for awhile. I have been able to get it running. It was really exciting to here it fire up. It started & sat there idling like a champ. It sound great. I should probably start a build thread.
      87.7 KB
    bct likes this.
  11. brady1929
    brady1929
  12. thirtytwo
    thirtytwo
    To get the car that low you would need a flat front crossmember , probably a 5" axle a 40 rear cross completely flat and a c-notch that goes past the frame rail
    Pleanty of other ways to do it like a kickup or z or spring behind axle but this is probably most straight forward
    Going to need a driveshaft tunnel and pumpkin clearance tho , and that low may require couple more inch c-notch than shown in back
    Eric1967 likes this.
  13. The37Kid
    The37Kid
    Welcome to the HAMB Eric, that blue Coupe does have a nice stance to it. I'm not a fan of the rear tires above the wheel wells, but that car sits well overall. Bob
  14. Cusco
    Cusco
    from Europe
    It is very 'simple' and beautiful.
  15. Fjant
    Fjant
    from Sweden
    Cusco likes this.
  16. Eric1967
    Eric1967
    from Union, Mo
    Thanks for the response guys. Getting some great info. thirtytwo are those pics from a build of yours?
  17. thirtytwo
    thirtytwo
    It was a frame I built for someone's roadster ... Someone else's project
    falcongeorge likes this.
  18. Eric1967
    Eric1967
    from Union, Mo
    Wow there are so many options. I am not sure what to do. I don't want to cut the body to pieces. No drive shaft tunnel or pumpkin clearance. I want to get it low. I know I want split wishbones on the front. Maybe 4" drop. I am planning on running 18" wire wheels. The car has an 8 inch rear end. Can I do the 40 rear cross member with a mild c notch. I do not want it raked a ton. I know the look I want just not sure how to accomplish it. I have been looking at pics. If I find the right look I will post it. How low can I get it & keep the stock floor?
    Thanks
    Eric
  19. 117harv
    117harv
    Yes, very nice. :)
  20. thirtytwo
    thirtytwo
    Lowest would be realistically about 1.5-1.75 c notch , put a 40 cross about 2.5 inch down from top of the frame , stock 40 spring perches at 48" , 31" tire will be about an 1" below the fender reveal , still going to need a blister for pumpkin clearance in the floor...
  21. Eric1967
    Eric1967
    from Union, Mo
    Do you think I am on the right track with a 4" drop on the front? Maybe a little lower with the cross member
  22. NashRodMan
    NashRodMan
    Good luck with the build. You have a great car to start with and a greater example to draw from.
  23. deucetruck
    deucetruck
    from Missouri
    Welcome to the HAMB. Lots of knowledge and great ideas floating around here.
  24. thirtytwo
    thirtytwo
    My crossmember was
    Broken in my roadster stock frame so I took that opportunity to flatten it out to. The bottom of the stock radiator that's about 2" ...
    My roadster has no c- notch but needs it ..., modified stock front cross / de-arch spring, stock front axle and stock rear cross with de-arched spring .... Technically your not going to get much lower than 2" more in front ( my stock axle is 2 1/2" drop) without serious mods ... My roadster stance is fairly simple and straight forward ....the extra 5" of the origional car you posted is not...
    Stock 32 has a pretty deep drop front cross , lose a lot of suspension travel when lowering it ... Me personally ... I'd probably find a nice stock A front cross and trim it to fit in the 32 frame
  25. Eric1967
    Eric1967
    from Union, Mo
    Thanks for the roadster pics. That's very helpful. I believe my car has a 42-48 axle & wishbones under it now. I can get a hold of a model A axel & wishbones from a friend if it helps. The floor is in great shape in this car. I would rather not cut it. I also don't want it to become a 10 year project. Would love to keep it simple for now.
  26. thirtytwo
    thirtytwo
    How about a pic of the axle? 42-48 bones have an s bend in them by the yolk , you can still use them if you like the appearance , model a bones are a little short , but I have used them, The A axle would be good candidate for dropping , wont work with 32-36 bones however unless perches are cut down to 2"
    Does your frame still have the k and stock mostly? , I might suggest to put a torq tube back in and unsplit front bone... That keeps it super simple!
  27. Eric1967
    Eric1967
    from Union, Mo
  28. Eric1967
    Eric1967
    from Union, Mo
  29. Eric1967
    Eric1967
    from Union, Mo
  30. Eric1967
    Eric1967
    from Union, Mo
    Axel
