Anyone have a source for sheet metal or aluminum sheet with the engine turning effect already done on it? Thanks for your help
I don't know of any but I've done some of it. Pretty easy really just takes a drill press and a wooden dowel the size you want the circles to be. Combine with lapping compound on the end of the dowel. Place a stop on your drill press table and make the first one. Move 1/2 hole sidewise and continue until that horizontal row is finished. Move your stop 1/2 hole and repeat. If you're doing a firewall you might want to use a large diameter dowell and bring your lunch cause it may take a while.
If it has to be metal then my suggestion won't be of any value. The cabinet industry has had a formica out for a while that looks identical. Formica is a trade name, as well as a manufacturer, but any supplier of plastic laminate should have a version of what looks to be engine turned metal. It works exceptionally well for flat dashes, will flex somewhat, and is quite durable.
sir: Izzat a good "Good Luck" or a warning "Good Luck" ? Cause I kinda like one of the dash plates...just wanted a heads-up before ordering.....Stan
Same question as Turbo26T. I know everyone I can think of gets theirs from them. Speedway, and Eastwood. Do they suck selling to the public?
An old hot rodder told me about the wooden dowel method only he used toothpaste for a compound. Cheaper and readily available.
I have a "hanline" dash in my "66" very happy with the looks and the gauges....as far as "fp-metals is concerned I have never delt with them personaly....
