Technical What rear lights were on this Model A?
Discussion in 'The Hokey Ass Message Board' started by Torana68, Mar 5, 2015.
  1. Torana68
    Torana68
    from Australia
    Guys,
    After a lot of looking I found an A coupe Body and brought it home, can anyone tell me what lights it had when it was over there? (it was imported from the U.S. ). Second photo is holes cut into the rear floor rails, seen this before but why was it done?
    Thanks
  2. jcmarz
    jcmarz
    from Chino, Ca
    looks like 41 to 48 Chevy tail lights.
    Maverick Daddy and 302GMC like this.
  3. Torana68
    Torana68
    from Australia
  4. looks more like 1946-1948 Ford passenger car tail lights.
  5. edcodesign
    edcodesign
    Shock mount clearance?
  6. X2 for the Ford units!
  7. My guess is '50 Buick light housings.
  8. scrap metal 48
    scrap metal 48
    That area of the sub rail rusted out a lot.. There used to be a wood block under it and a through bolt that bolted to the frame.. Looks like they just dressed it up a bit instead of repairing it...
  9. 42merc
    42merc
    Tail lights were '41-'48 Chevrolet.
  10. I have 48 Chevys on mine and the holes look more like the 48 Fords to me.
  11. 31Apickup
    31Apickup
    As Scrap Metal 48 stated, that area of the rear sub-frame is where the rear wood body block mounts to the rear cross-member. It is very common area for this area to rust out or have stress cracks.
  12. 4-pot
    4-pot
    jcmarz and 42merc are correct on the tail lights. I have those on my 30.
  13. Torana68
    Torana68
    from Australia
    thanks guys :) if I measure the distance between the mounting holes will that help?
  14. Rusty O'Toole
    Rusty O'Toole
    I was going to suggest that.
  15. flthd31
    flthd31
    They are 41-48 Chevy as already mentioned. I have them in a coupe. You can see in the pic that the studs in the housing match you holes...one is centered and one is off-set.
  16. Torana68
    Torana68
    from Australia
    I think the offset stud man wins! Ill go find a set, don't think this was ever a show car but its seen some use :) funny how they cut the rust from the floor rail then just left it that way. Thanks Guys :)
    (distance between studs should it matter is 103.4mm a smidge over 4")
  17. I wouldn't rule out 42-48 Ford. HRP
  18. Torana68
    Torana68
    from Australia
    offset mounting studs on those too?
  19. Nope. HRP
  20. Baron
    Baron
    Just measured the set I have and the studs are about 4 1/8 ".
  21. Torana68
    Torana68
    from Australia
    The Chev ones?
  22. Baron
    Baron
    Yes.
  23. Torana68
    Torana68
    from Australia
    righto Chev taillights will be going back on it, thanks again
