History What is it? Supercharger?
Discussion in 'The Hokey Ass Message Board' started by Inline, Aug 23, 2016.
  1. Inline
    Inline
    from Ohio
    So, I got this in a trade recently. I have no idea what it is. Maybe a supercharger? Maybe a natural gas conversion? There are no markings and it appears to be very well made. It has a large Rochester 2 barrel base so it can't be any earlier that the 60's. Someone definitely spent some time working on this thing.
    When you spin the pulley, you can see something spinning through the base plate. There doesn't appear to be much of a reduction or increase in gearing. I haven't taken it apart yet but will.
    So, the story that I was told was that the guy I got it from bought it at an auction of a retired GM engineer. The guy's son apparently explained that this was a project that his dad worked while at GM and was able to take it with him when he left. He also said it was displayed on the mantle for as long as he could remember. There was supposedly a display stand but at the time of the auction, they couldn't find it. I don't know if any of this is true or not. Also, the guy I got it from couldn't remember the guys's name so I really have nothing to go on.
    So what does everyone think?
    turboroadster, Jet96 and LONG like this.
  2. F&J
    F&J
    bolt that dang thing on and see wut happens ..LOL
    100 mpg doo dad, so be careful posting the results. As "big oil" will hunt you down :)
  3. squirrel
    it's an old supercharger, adapted to fit a V8 GM engine from the 50s, most likely.
    sort of similar to the Frenzel, more similar to that used on the Graham. but I don't think it's either of them. keep looking...but I doubt you'll find anything like it, it appears to be hand made.
    lothiandon1940 likes this.
  4. Mike51Merc
    Mike51Merc
    So, what happens when you turn the pulley? Do vanes spin? Suck & blow?
    My impression is that the housing is too small to handle enough volume to supercharge any automobile engine with a reasonable displacement. Maybe just a fuel atomizer spinning around?.
    loudbang, Hnstray and F&J like this.
  5. gnichols
    gnichols
    from Tampa, FL
    Might it be for a flathead, IVO the long shaft and V-belt pulley? Wonder what the carb flange fits? Gary
    turboroadster likes this.
  6. squirrel
    The carb flange is the 2bbl Rochester, it's actually the throttle body from a carb. I think the gizmo replaces the carb, on something like a Chevy 265. Really neat, I'd have to take it apart and investigate....
    lothiandon1940 and turboroadster like this.
  7. Inline
    Inline
    from Ohio
    I thought it might be some sort of fuel atomizer as well. Once I get some time, I'll pull it apart and take a bunch of pictures.
    The length of it would lend itself to bolt onto a SBC 2 barrel intake. It even has a tapered wedge between the carb base and housing to account for the angle of the carb.
    The linkage between where the fuel line port and the barrel for the air cleaner almost appear to be vacuum controlled. There are no signs of linkage between that and the throttle plates.
    F&J likes this.
  8. patmanta
    patmanta
    from Woburn, MA
    1. MASSACHUSETTS HAMB
    It's COOL whatever it is. I'm in the BOLT IT ON AND SEE camp!
    lothiandon1940 and kiwijeff like this.
  9. Phil1934
    Phil1934
    I'm going with some kind of fuel injection as no float for carb body, a lever that links carb back to gizmo and a fuel line to gizmo
    caddy daddy 47 and Hnstray like this.
  10. Dave Downs
    Dave Downs
    from S.E. Penna
    The part that looks like a carb sort of looks like a Fish carburetor (yes, they were real!), have no idea what the impeller/rotor does - maybe stirs up the mixture.
  11. F&J
    F&J
    It has a grease fitting...maybe grease that and hold the pulley against a wire wheel on a bench grinder, to spin it and see what happens?
    I was looking at that linkage. Both "sliding"ends are very adjustable...like they were really guessing with the ratio between that double ended link. One end is going to the top of the right angle gearbox...so, does that mean the gear shaft speed controls that twin link going to the venturi?... and if it does, the other end of linkage on the top of the right angle box, has that fuel elbow thing...is that the flow of "fuel" being regulated by the gearbox speed?
    keep us informed, please :)
  12. linechaser32
    linechaser32
    from Iowa
    Pulse generator.
  13. Hnstray
    Hnstray
    from Quincy, IL
    Turbo-Encapsulator!!.....:D
    Seriously, I agree with the suggestions that it is a fuel atomizer, replacing the conventional carburetor for that function.
    Ray
  14. blowby
    blowby
    from Nicasio Ca
    Whatever it is, chrome it.
    49ratfink, Murphy32, dan31 and 5 others like this.
  15. jhexide
    jhexide
    possible a unit to burn natual gas or propane
    alphabet soup likes this.
  16. Looks like it might be a compound compressor/supercharger, or a super duper shit masher. Lots of crazy stuff showed up in the early 70s "gas crunch"
    dan31 likes this.
  17. Cosmo49
    Cosmo49
    "If my calculations are correct, when this baby hits 88 miles per hour... you're gonna see some serious shit."
    LostBoy, cfmvw, cadillacoffin and 6 others like this.
  18. Marty Strode
    Marty Strode
    If you call it an "Advanced Induction System" and make claims of remarkable fuel mileage, maybe the Arab Oil Producers will pay you a small fortune to keep it off the market.
    falcongeorge likes this.
  19. 56sedandelivery
    56sedandelivery
    A bunch of stuff was supposed to be left behind after the lunar landing, but someone obviously did't follow protocol!
    I'm going with some sort of atomizer, and not the kind at the fragrance counter.
    I am Butch/56sedandelivery.
  20. I think it looks like an engineers attempt at better mileage on a small ci motor. Experimenting back when we were an industrial nation.
    Even more awesome is that there are guys like yourself that see this and save it from the scrap pile. Most folks see it as junk when it really is probably many years worth of some guys stress and sleepless nights deep in thought about it.
    young'n'poor, patmanta and Hnstray like this.
  21. patmanta
    patmanta
    from Woburn, MA
    Have we considered maybe a Wood Gasifier application?
  22. treb11
    treb11
    Some kind of pressurized fuel atomizer. I bet all those spots on the bottom of the lower housing are where vanes are located. The control rods probably connected to levers on a dyno stand.
    Or a chingadera if you're from Texas
    Sent from my SM-G550T using The H.A.M.B. mobile app
    texasred likes this.
  23. badshifter
    badshifter
    Stationary / industrial Engine governor or regulator?
  24. mikeymike
    mikeymike
    Patmanta is absolutely right; it was common during WW II using wood as fuel, at least in Europe.
  25. lippy
    lippy
    from Ks
    Looks like an earshplitten loudenboomer.
    49ratfink and KoolKat-57 like this.
  26. cj92345
    cj92345
    from so-cal
    ok, I'am guessing industrial, some kind of RPM limit, governor for maybe an automotive engine on a big pump...regulate engine speed with how fast the pulley is turning....or maybe not
  27. Inline
    Inline
    from Ohio
    So I finally found time to disassemble this thing. What do you guys think of these pictures?
    gimpyshotrods and turboroadster like this.
  28. Bubba1955
    Bubba1955
    Atomizer...No vanes to pressurize.
  29. Mike51Merc
    Mike51Merc
    I knew it! An early version of a flux capacitor!
    I'd bet those prongs are magnetized.
