Hot Rods Tips needed to remove paint from stainless.
Discussion in 'The Hokey Ass Message Board' started by Toqwik, Mar 20, 2017.
  1. Toqwik
    Toqwik
    So the PO did his best to protect rust spots on my 53 but in the process he chose not to tape off and trim and got a little carried away with the paint bomb. The stainless is in good shape and I don't want to create more work for myself. What works best for you? [​IMG]
  2. gimpyshotrods
    gimpyshotrods
    Try acetone or lacquer thinner on a rag, with appropriate PPE.
  3. *MEK not legal for industry but you can still buy it at any home improvement store.
    * methyl ethyl ketone
    gimpyshotrods likes this.
  4. 6-71
    6-71
    Lacquer thinner is my go to solvent for a job like that. it will cut just about any kind of paint.
  5. rusty rocket
    rusty rocket
    If lacquer thinner doesnt work and you are careful you could use a gel type paint remover.
  6. Toqwik
    Toqwik
    I was going to try paint remover because I had some but was afraid it might react with the stainless. Good to know.
  7. Knghtcadi
    Knghtcadi
    I wet sanded mine with 3000 and buffed them now they look new
    kidcampbell71 likes this.
  8. Jalopy Joker
    Jalopy Joker
    ultra fine steel wool helps too
    Bugguts and flatford39 like this.
  9. metalman
    metalman
    On the car or is it off? On the car I'd go after it with triple 0 steel wool, stripper or ever lacquer thinner could get on the paint you want to keep. If the trim is off then stripper, not many chemicals will effect stainless.
  10. deuceman32
    deuceman32
    If the trim is off, good old brake fluid will soak off anything short of epoxy with no nastiness
  11. Sheep Dip
    Sheep Dip
    from Central Ca
    You can tape off the paint next to the trim to protect what paint is there and use quad #0000 steel wool to remove and shine your trim back to life.
    Bugguts likes this.
  12. Squablow
    Squablow
    I've used gel stripper on stainless many times and never had an issue. I assume you're doing this off of the car anyway, although lacquer thinner might work and be easier if it's just cheapie spray paint.
  13. Easy Off oven cleaner.
    Spray it on, give it a chance to work (several hours) spray it with water then scrub with fine steel wool or an SOS pad.
  14. flatford39
    flatford39
    Steel wool. A very non abrasive grade.
  15. deathrowdave
    deathrowdave
    from NKy
    All the chemicals as suggested , just be careful and wear PPE , many are really bad , and enter through the sink . I tell everyone , gooogles are a must , eyes are a hard item to buy , "NOS " .
  16. belair
    belair
    Super fine steel wool. Cleans glass too.
  17. Roger O'Dell
    Roger O'Dell
    All the above works, but unless some really good prep was done. It will pop off with a razor.
  18. I can't get paint to stick to stainless.
    :confused:
    Jalopy Joker likes this.
  19. 33pickemup
    33pickemup
    0000 steel wool works the best, if you don't want to hurt the paint, run a tape line down both sides. A good metal polish after that and they will look really good.
    Dennis
