Projects street rod 32 made in france
Discussion in 'The Hokey Ass Message Board' started by mr 32, Jan 27, 2011.
  1. 60galaxieJJ
    60galaxieJJ
    super high quality build!
  2. nali
    nali
    Not sure you got the answer. If you need any help to translate, I can help.
    I live in Quebec but I m from Toulouse / Montauban.
    Philippe.
  3. mr 32
    mr 32
    from france
    thank s
    I let my friend nali translate
    here's more
  4. mr 32
    mr 32
    from france
    hello , tous le monde
    bon je vous dis a quoi sert tous ce montage :face:
    voici quelque tof et on en reparle après :mrgreen:
    ça commence toujours comme ça
    avec un croquis
    après on affine
    on fait quelque motif
    :lol!: :lol!: :lol!:
    looking
    made
    kidcampbell71 likes this.
  5. mr 32
    mr 32
    from france
    nice looking :)
  6. nali
    nali
    Nice !
    Pix are quite self-explanatory, so I didn t have to translate anything .
  7. redzula
    redzula
    cool shift linkage.
  8. 30TudorSedan
    30TudorSedan
    Nice looking shift linkage!
  9. mr 32
    mr 32
    from france
  10. 3wLarry
    3wLarry
    from Owasso, Ok
    I'm curious what you were doing to the trans tunnel with that torch...heating the metal so you can leave it bare without rusting?...and it looked like it had a coat of clear on it when you were done...
  11. DaveyJonez
    DaveyJonez
    from Houston
    Great work-
    Really different and bitchin'!!!
    Best from Texas,
    Dave
  12. SniffnPaint
    SniffnPaint
    You've got a lot of cool details there.
  13. CRH
    CRH
    from Utah
    Making the most of the donor car and fabricating EVERYTHING...very cool.
  14. afaulk
    afaulk
    Beautiful work!
  15. captain scarlet
    captain scarlet
    from Detroit
    Not sure but I think he covered it in oil first and burned the oil into the metal to give it a smoked look.:confused:
  16. 3wLarry
    3wLarry
    from Owasso, Ok
    I wish he would tell us more...and not in French...:D
  17. nali
    nali
    Don t worry 3wLarry, I translate when necessary.
    Or maybe you SHOULD worry :)
    mr32, tu as fait quoi au juste avec ton chalumeau ? Mis de l huile sur ton cache pour la bruler ? Ou simplement bleuir le métal sans dessus ?
  18. mr 32
    mr 32
    from france
    thank s
    donc j ai chauffé la tôle pour bleuir le métal et après on jete de l huile dessus pour lui donner un aspect vieilli , après on le patine avec de la laine d acier et cela donne le résultat d une armure vielle de 150 ans :)
    un coup de graisse de mouton de temps en temps et il ne rouillera jamais :)
    je vous remercie pour tous vos commentaires , cela me donne la pêche pour la suite
    encore merci
    si tu veux bien traduire nali , je te remercie c est cool
  19. nali
    nali
    Explanation about the torch on the trans cover :
    " The trans cover was first heated, just enough to make it blue. Then, some oil was thrown over it to give a vintage look.
    Finishing was done rubbing with steel wool, and the result is it looks like a old 150 y/o armour ( nb: which is in fact quite wrong, they stopped using armours when firearm appeared, it was inefficient. So it s 500 or 600 y/o, not 150 ).
    Regular use of tallow avoid rusting. ( omg... Fortunately it s a convertible, imagine the smell )
    Thanks for the comments, this give motivation"
    Pour info, l usage des armures a cessé vers la fin du Moyen age il y a 500 ou 600 ans, la découverte des armes a feu les a rendues obsoletes :)
  20. mr 32
    mr 32
    from france
    thank nali :)
  21. mr 32
    mr 32
    from france
    voici un p tit peux de new , je vous passe les détail de la lime pour les gueules de loups
    il me restait une modif a faire pour le compteur du milieu chose faite :D
    la suite en image
    nali please :)
  22. mika112
    mika112
  23. nali
    nali
    Je suppoise que je vais devoir traduire,,,
    Tu fait chier :p
  24. nali
    nali
    IMost of the work is home made.
    Mr 32 have skills.
    It s quite, I just translaté
    You can t what you waInt, till yoI u know ahat you wanr ( Joe Jacson )
  25. mika112
    mika112
    ;) lol !!!
  26. OahuEli
    OahuEli
    from Hawaii
    Wolves? Us? Nah! :D
  27. mr 32
    mr 32
    from france
  28. mr 32
    mr 32
    from france
  29. mr 32
    mr 32
    from france
  30. mika112
    mika112
    courage you will see the end.
    I look forward to seeing you ride :)
