straight pipes on I6
Discussion in 'The Hokey Ass Message Board' started by Evilfalcon1961, Apr 16, 2008.
  1. Evilfalcon1961
    Evilfalcon1961
    from Ma
    thinking about getting a new exhaust would straigght pipes on a 200 i6 sound good?.. or should i stick with a muffler???
  2. Evilfalcon1961
    Evilfalcon1961
    from Ma
  3. not so hotrod
    not so hotrod
    Ive heard that small true dual exhaust on stovebolt 235's sound excellent. I dont remember what size though. Pretty small.
  4. gearsforguts
    gearsforguts
    from temple,pa
    i ran duals with glass packs on my 61 falcon 200 inline six and a dual outlet header sounded good
  5. oilslinger53
    oilslinger53
    from covina CA
    1 1/2" dual straight pipes with tapered tips sound good on a 235, dont know about a 200 though
  6. Muffler on anything but a V8.
  7. starchief1959
    starchief1959
    Had duals on a split manifold 235. Sounded pretty good. Higher pitch but still had some grunt.
  8. Bort62
    Bort62
    A strait 6 under load @ high RPM sounds very different than a V8. It's up to you whether or not it sounds good.
    I don't think I would run strait pipes on a falcon regardless.
  9. DE SOTO
    DE SOTO
    My daughter ran a straght pipe on her 170 6cyl '62 Falcon for a couple years. She just sold it & one of the selling features to the guy who bought it was how cool it sounded.
    I was against it but she had to have it, So i did it & to my surprise it sounded really Cool for a lil car like that.
    It was a Stock manifold & single Pipe all the way out.
    Sounds Good till ya lose a Gasket, Then popped so we always knew when to fix the Flange gasket.
    I dunno about Duals though.. I had Duals & Mufflers on a 225 Dodge 6 that sounded REALLY good... Then i straight piped it and it sounded like SHIT !!
    REALLY Loud & everyone said it sounded like an old Bi~Plane....ONLY LOUDER !!
    I hated the Dodge Slant on straight Pipes... But the Falcon sounded good .
  10. Tony
    Tony
    I run 2" dual's with a split manifold and SHORT stainless packs on my 235..the muffler body is only about 9-10" long and they are mounted as far forward as possible...I love the sound..
    Rumbles like a small 8 at idle then has a nice toned low 'buzz' at speed..
    It's loud enough that it can be heard but not obnoxious.
  11. Johnnyzoom
    Johnnyzoom
    from Florida
    Tried this and glasspack combinations on my Comet with 200 i6, I was disappointed. Maybe with headers it would be cool, but without it sounded like what it was: a small 6 without a muffler.
  12. Dan10
    Dan10
    from Joplin
    I ran a dual exhaust on my ford 223 inliner and I thought it sounded good. I did put mufflers on it later as it was hard to sneak into the house at 4 am. without them.
  13. I think it depends on tube diameter, length and what have ya. I'm running a 22" glasspack with 2 1/4" pipe on Ford 250 inline all the way out the back and it has a drone at certain speeds/rpms, but sounds good at top-end.
    Going with a 2" pipe next time.
  14. ray
    ray
    straight pipes on a small ford six sound absolutely SICK! and by sick i mean good. when you split the manifold on these, you get a 2/4 split, so it raps like nothing else out there. when i did mine, i was infleuenced by a certain slant 6 with straight pipes, as well as the old chevy bombs running straight pipes, neither sound as good as a split ford six.
  15. I'm running a single exhaust , with 2" tubing and a single 'Cherrybomb' muffler on my stock '51 216ci and it sounds fairly deep and cool.
    Cooter
  16. Skankin' Rat Fink
    Skankin' Rat Fink
  17. hillbillyhellcat
    hillbillyhellcat
    I had a 250 ci Ford in a Falcon with a Cliffy dual outlet header and Heartthrob brand turbo style glasspack mufflers (JC Whitney) and meg's tips.... It sounded awesome for a six cylinder.... Everyone thought it had a hot 289 in it... Funniest part was when I swapped to a V8 with the stock exhaust it sounded like crap! Good setup for a 6 though.
  18. Lucky444
    Lucky444
    If you do a search for this you'll get alot of info. Here's some I found. I had a 170 in a Falcon that I kept the stock manifold and ran only a single Flowmaster with 2" pipes, sounded deep and throaty with a hint of "rap" at full throttle. Now I've got a split manifold on a Chevy 250 going into 1.75" pipes, one straight through and one Brockman Steel pack. Sounds rowdy and has that "rap" unique to sixes with duals. Sounds like a Biplane on the freeway.
    http://www.jalopyjournal.com/forum/showthread.php?t=168439&highlight=split+exhaust
    http://www.jalopyjournal.com/forum/showthread.php?t=194749
    http://www.jalopyjournal.com/forum/showthread.php?t=59126&highlight=straight+pipes+glasspacks
  19. willowbilly3
    willowbilly3
    from Sturgis
    Yeah, that V8=good sound, 6=sound not so good.
  20. Lucky444
    Lucky444
    [QUOTE Yeah, that V8=good sound, 6=sound not so good.[/QUOTE]
    To each his own...a split six is music to my ears!:D
  21. Evilfalcon1961
    Evilfalcon1961
    from Ma
    yea nice... i have an exhaust cutout right behind the header and it sound like a plane at idle... but on the throttle it sounds mean.. already have the header on there so seems like im going to split it and run duals and dump right before the rear axel or run em all the way back
  22. Evilfalcon1961
    Evilfalcon1961
    from Ma
    so i should be running a 1 1/2 pipe i think its a 2 or 2.5 now but the cutout is never capped anyways... but no backpressure so tis bad!
  23. Lucky444
    Lucky444
    The smaller diameter pipes will be better when you split it into two. If you run em all the way to the back of the car the longer pipes will give you some back pressure and the noise won't make you prematurely deaf! If you do dump the exhaust before the rear axle make sure you point the tips out the side of the car or else the resonating will kill you. I've got mine running all the way to the back under the axle.
  24. LabRat
    LabRat
    Glad your still not thinkin about takin the paint off , playing around with your pipes is alot better idea .....
  25. VNCduke
    VNCduke
    from Washougal
    Id worry about making your car less crappy before you make it even crappier..you know, balance it out a little bit
  26. Evilfalcon1961
    Evilfalcon1961
    from Ma
    haha right you are sir .. right you are
  27. Gasserman
    Gasserman
    from Tulsa OK
    My 170 is a plus .030 motor with a solid lifter cam and Clifford split header with duals . But it sounds real good ,not you standard run of the mill I6 . I like it. Gasserman
  28. Evilfalcon1961
    Evilfalcon1961
    from Ma
    thanks for the advice .. Kid
  29. KIRK!
    KIRK!
    Personally, I love the sound of a six screaming and popping through 1 1/2" straight pipes.
  30. Evilfalcon1961
    Evilfalcon1961
    from Ma
    hell yea dude!
