Projects sport coupe build
Discussion in 'The Hokey Ass Message Board' started by Genes12320, Sep 1, 2015.
  1. Genes12320
    Genes12320
    I am going to start the build of my sport coupe. It came to me here in Maryland from southern California about 10 years ago. I took it as partial payment for a construction project after the customer was unable to pay. I has been sitting here in the shed since. I have been collecting parts here and there. 51 F1 brakes, 70 Bronco rear, and other small items I have a 406 Ford FE with factory Tri-power rebuilt and sitting on the stand waiting.
  2. Genes12320
    Genes12320
    I ordered a frame from Eric at Riley Automotive. The front end is from Pete and Jakes, and the spring is a Posies super slide. I am using the 51 F1 brakes that I had with 66 F100 hardware and self adjuster kits. I ordered the brake parts from Rock Auto. I am painting all of the steel parts with epoxy primer and black basecoat/clearcoat as I go.
  3. 55willys
    55willys
    I like it. Are you running fenders or fenderless? You will most likely have to cut or reverse the firewall to get that engine to fit in unless you use a 32 frame and stretch the hood.
    Genes12320 likes this.
  4. Genes12320
    Genes12320
    I am going fender less, chopped, and channeled. Eric is making the frame with a extra 6 inches because I want to keep the stock firewall
    volvobrynk likes this.
  5. good move on the extra 6" not much room in those A's. I put an extra 5" in my frame to get a Y block in without cutting the firewall.
    volvobrynk and Genes12320 like this.
  6. A chopped Sport Coupe? Don't think I have ever seen one. I think I would try to trade the body for a standard coupe for that. It might be easier.
  7. Binger
    Binger
    from wyoming
    Looks like there is juice brakes on it already? Looking at the brake pedal in the interior and the brake drums.
  8. Genes12320
    Genes12320
    I think it should be a easy chop. Just cutting the door jambs and doors, and windshield frame. I can modify the wood and get a top made. I am planning on lengthening the top of the door frame and the floor to make flosh doors.
  9. Genes12320
    Genes12320
    I liked the look of Eric / Riley Automotive's swept frame. I called Eric and he was very helpful. He sent me a proposal that was basically his rolling chassis less spindles and brakes, and less the rear since I had that. I paid half and he sent me all of the parts right away. I have already received everything other than the frame itself. He is shipping the frame Friday and charging the balance then. I have no complaints at all. The parts were great American made stuff. Pete & Jake's and Posies for the most part. Communication has been great.
    volvobrynk and -Brent- like this.
  10. Genes12320
    Genes12320
    I was trying to find pictures of De Soto's car but no luck. I don't know my way around here very well. Got any?
  11. Stovebolt
    Stovebolt
  12. Genes12320
    Genes12320
    I got the body off of the frame and on a rotissere Model A 001.JPG Model A 002.JPG Model A 003.JPG Model A 004.JPG Model A 005.JPG Model A 007.JPG Model A 006.JPG
  13. Genes12320
    Genes12320
    I blasted the 35 wires that were on the car. I sprayed them with epoxy primer and then primer surface. I sanded them tonight and sprayed them with black basecoat. I will clear them in the morning. What a PITA a wire wheel is to paint.
    volvobrynk, hipster and kidcampbell71 like this.
  14. Genes12320
    Genes12320
    Great coupe Stovebolt. What is that grille shell?
  15. Sounds like you got your frame,suspension stuff solved good news.
  16. Genes12320
    Genes12320
    I assembled the front end. It is a Posie's spring and the rest of the new stuff is Pete & Jake's. I had the spindles and F1 brakes. I rebuilt the brakes and used hardware and self adjusters for a 66 f100. I had to cut an additional adjustment opening in the left backing plate. I painted all of the steel parts with epoxy primer and base/clear black. I bought 1 1/4 spacers and the supports for the 35 wire wheels.
    I mounted up the tires tonight also. 550-16 front and 750-16 rear. It was a good thing that I thought I should keep some spare tubes on hand. I ripped the stem off of one. I haven't mounted tubes in a while. I need a little practice.
  17. Genes12320
    Genes12320
    Here is the engine for the car. I have had it done for about 5 years DSC07117.JPG DSC07117.JPG DSC07117.JPG DSC07116.JPG DSC07122.JPG DSC07119.JPG DSC07117.JPG
  18. DE SOTO
    DE SOTO
  19. DE SOTO
    DE SOTO
    Here are few more recent pics of My Sports Coupe
  20. shortypu
    shortypu
    Man i love the look with those wheels and the top.I walk around your car every time I see it at the primer nats.
  21. Genes12320
    Genes12320
    Cool car De Soto. How many inches of chop? What is that dash?
  22. DE SOTO
    DE SOTO
    6" Chop .. '51 Ford truck Dash .. '26 Chrysler Radiator
  23. Genes12320
    Genes12320
    I received my frame from Riley Automotive today. It was 2 weeks from the order to the frame being shipped. It looks great. My son Chris and I took it off of the pallet this evening and started completing the mock up. DSC07123.JPG DSC07123.JPG
    volvobrynk and OL 55 like this.
  24. Genes12320
    Genes12320
    I got the rear end assembled and bolted in. I am planning on setting the engine and trans set next.
    DSC07332.JPG DSC07331.JPG DSC07330.JPG DSC07329.JPG DSC07328.JPG DSC07327.JPG DSC07326.JPG DSC07325.JPG
  25. Genes12320
    Genes12320
    I am thinking that I should figure out where the radiator will be and set the fan to it. Then I would need to do whatever is needed to the firewall. I am also looking for thoughts on how the engine should set. If I make the carbs level on this tripower, the engine is down in the rear. Will that look odd? Would the carbs work correctly if I set the engine level?
  26. Genes12320
    Genes12320
    I got the engine and trans in place The engine looks high to me but the trans can't go lower. I leveled the carbs and set the fan Where Walker told me it should be. Any comments before I weld in the mounts?
    DSC07333.JPG DSC07334.JPG DSC07335.JPG DSC07333.JPG DSC07334.JPG DSC07335.JPG DSC07336.JPG DSC07337.JPG DSC07338.JPG DSC07339.JPG DSC07340.JPG DSC07341.JPG DSC07342.JPG
  27. Genes12320
    Genes12320
    I was hoping to get some comments on the engine placement. The trans yoke has 3/8 clearence so can not go lower. I also think I should swap the deep pan on the trans for a standard. I then leveled the carbs, but it seems high to me. I am wondering if I should drop it lower in the front. Do the carbs need to be level? Where is the fan usually in relation to the front crossmember?
  28. From the pics I can't really see why it wouldn't go where you have it. I have always set the engine install angle level at the carb flange but keeping driveshaft angle in mind. You just want to mimic the chassis' rake at its target angle. If you level the carb flange and then change the rake or alter the ride height after the fact you may encounter issues. If you are unsure you could tack everything really good and continue with the build. Then if you have to change something it's not a big mess to cut up. Also I would mount the radiator and get the fan to radiator relationship established asap. Hope this helps.
    Hack
  29. A Boner
    A Boner
    Where does the firewall end up in relation to the back of the engine? Height wise will the driveshaft go under the floor, or how much of a driveshaft tunnel will be needed?
  30. Genes12320
    Genes12320
    I am going to try and get the body set on Sunday. I am planning about a 3" channel, so I will be installing a tunnel as needed. I was actually going on Posies' recommendation to set the front to place and then do what is needed to the firewall. The frame has 6" added ahead of the cowl. I am hoping to keep as much of the stock firewall as possible. What do you think of the height of the engine. The transmount is bolted up and I have the oil pan setting on a jack now.
