some of the work from my shop
Discussion in 'The Hokey Ass Message Board' started by cornfieldcustoms, Nov 15, 2011.
  1. cornfieldcustoms
    cornfieldcustoms
    i use the english wheelto pre stretch the area where the beads will be but you can use a hammer and dolly or planishing hammer if you dont have an english wheel. figuring out how much to pre strech the panel will come with practice and getting a feel for it
  2. cornfieldcustoms
    cornfieldcustoms
    a little progress on the RPU tonight. started making the floor pans and trans tunnel
    floor pans cleco'ed in place
    want to make the trans tunnel as small as possible since room is tight in this one. so i made some blisters in the tunnel for clearance. also had to make a blister to fit around where shifter comes out. so here are the basic steps i took to make the big weld on blister
    blister laid out, the black line is the hightlight or edge line of the blister
    using thumb nail shrinking dies in the recip. hammer. i shrink up to the black line
    all the shrinking done
    after a trip through the planisher
    and all welded on. you can see all the other blisters formed in the tunnel, stills needs to be hammered and dollied and metal finished out, but that will wait until i get all the other panels made and fit up
  3. cornfieldcustoms
    cornfieldcustoms
    starting forming the front part of the trans tunnel
    Hotrodmyk, AHotRod and Bam.inc like this.
  4. willymakeit
    willymakeit
    Youre work just makes want to give up. Nah keep posting as Im still trying to learn. Hats off.
  5. cornfieldcustoms
    cornfieldcustoms
    a little more progress on the floor and tunnel
    and made some new upper cowl braces. looks much better
    and had a photo shoot with the Riley roadster i built last year for my new website i having done
  6. Bam.inc
    Bam.inc
    from KS
    Floor work is really awesome. Keep the pics coming, great inspiration & ideas for my winter 'to-do list'. Seems I've been stalled out on my 'A floor pans & you have made it look so easy. MAD SKILLs
  7. cornfieldcustoms
    cornfieldcustoms
    started tig welding up the sides of the body
    after a little grinding and some dykem for guide, and a pass with the file
    hammered and dollied for a while. then hit it with the high speed sander with 80 grit
    started with the DA on the top half, still need to work on the bottom some more. it is a tough spot to get to since i have to hammer left handed
    got this one down off the lift for some work, put the new wilwood discs on the front, and starting on rear suspension
  8. loudbang
    Wow somebody actually using safety wire. Great work and nice touch.
    jakespeed63 likes this.
  9. ago
    ago
    from pgh. pa.
    I use safety wire on my header bolts, suspension, brakes and steering.
    Ago
  10. cornfieldcustoms
    cornfieldcustoms
    making progress on this one even though it is not necessarily hamb friendly but what the hell i will post cool pics of it . wanted to do something neat on the rear suspension and tried to same some room. so i decided to go with a cantilever coil over set up, nothing to crazy. everything works great and no issues through complete suspension cycle. still needs some minor things finished up
    working on design and set up
    all mocked up minus some little things like spacers and more tube work
    laidout53 likes this.
  11. ago
    ago
    from pgh. pa.
    Corn fields, nice work.
    Changing the rocker arm ratio can make the coil overs progressive?
    Ago
  12. cornfieldcustoms
    cornfieldcustoms
  13. harleycontracter
    harleycontracter
    You do awesome work. What a talent !!!!!
  14. Cornfield, Just ran across this thread and I am in awe over that transmission tunnel. Would be a shame to cover it up. Never seen anyone make those little tabs, along the edge. Nice touch!! The bomber seat, on page one ain't too shabby neither.:cool: Ever heard the term "steam punk" ??
    As far as the cantilever suspension, first off it is way cool. How does that geometry help the suspension dynamics??? Hamb friendly??? Did you see Ryan's post earlier this week, about the European classics influence, on the Hot Rod world? The bar is being raised every day, by craftsman, such as you( and crew) Thanks for sharing.
    JT
  15. cornfieldcustoms
    cornfieldcustoms
    thanks man, as far as the suspension, the way i have this set up it is just a 1:1 ratio so the spring rate and dampening will be the same as if they were mounted vertically.
    i wish i had a crew to help me out lol. it is just me all day talking to myself lol.
    62hotcat likes this.
  16. MP&C
    MP&C
    Mike, that's just true art form right there. It would be a shame to cover it up! Nice work!
  17. cornfieldcustoms
    cornfieldcustoms
    thanks robert, i hope i can sway him into a neat little truck bed
  18. cornfieldcustoms
    cornfieldcustoms
    back to some good progress on the RPU. we stretched the rear of the chassis to help support the bed. ten mocked up a model T bed to get the idea of the stance on the truck. starting to look pretty good
    then i got a crazy idea to do an all aluminum bed that is a close version of a factory be. here is the pass. side roughed in
    should be able to get a lot more done in the next few days on the bed
  19. tobyflh
    tobyflh
    from Peru il
    That is some great work. One question how did you do the top of the bed sides?
  20. cornfieldcustoms
    cornfieldcustoms
    i did the square on the top bed rails in a standard sheet metal brake.
    here is todays progress. got the rear bed wall roughed in and cleco'd in.
    started working on stake pockets
    here is the over look for the day
  21. Nice work and I too wish I was closer to your shop as I sure could use some holes punched in my deck lid.
  22. I also would like to see a nice shot of the 5 window on the wall....That looks to be very cool wall art.
  23. cornfieldcustoms
    cornfieldcustoms
    i think i have a build thread on here for the coupe. i s the " minges coupe"
  24. cornfieldcustoms
    cornfieldcustoms
  25. cornfieldcustoms
    cornfieldcustoms
    a little more progress. aluminum bed almost all roughed in. not to decide if i should make a new aluminum tail gate, or run the nice original one....... to many decisions
  26. cornfieldcustoms
    cornfieldcustoms
    started helping out Joshua Shaw on some sheet metal work on a custom 1941 Packard Darrin town car.
    here is the goal of the build
    started on the passenger front door skin. put all the shape in the panel with the English wheel, then tipped the edges over on the bead roller
  27. custom 1941 Packard Darrin town car.???????
    Holy crap, the HAMB bar has just gone up at least 3 notches. What an unbelievable project.
    ...and it's NOT being built in California. ;)
    JT
  28. Jibs
    Jibs
    Man you gotta change the title to "Some of the art from my garage". Nice!!
  29. captainjunk#2
    captainjunk#2
    don't know if you ever get tired of hearing it , but man you do some awesome metal fabrication , fascinating stuff
  30. cornfieldcustoms
    cornfieldcustoms
    thanks a ton guys, i am sure this thread is rough to follow since i am always jumping around and working on 100 things at once lol. i will keep posting as i do cool things
