solder or replace brake line?
Discussion in 'The Hokey Ass Message Board' started by dallasdrifter, May 8, 2011.
  1. rustyford40
    rustyford40
    from Mass Bay
    Replace all the brake lines and put in a duel master cylinder. DO IT RIGHT!
  2. Toner283
    Toner283
    There are pre made sections available in 6 inch, one, two, three, four and five foot pre flared, fittings already on the line, ready to use pieces. how long of a line do you need to replace?
    Also, no one has mentioned it yet but along with the don't weld or solder a brake line, never ever EVER use compression fittings on brake line. If any of these repairs were discovered by the police after you had an accident, you would be in deep shit up to and possibly including jail time.
  3. JOECOOL
    JOECOOL
    I want to be the first one to tell you to solder it, or use JB Weld. It will be fine.
    P.S. please give your wife my email address and ask her to let me know when the estate sale is going to be! send pic's of all your stuff.
  4. MrSpade13
    MrSpade13
    Please please please dont even consider doing anything but replacing the line.
  5. rusty bill
    rusty bill
  6. 39 All Ford
    39 All Ford
    from Benton AR
    And,,,, a 60" stick is more than enough to reach from the distribution block (or m/c) to the right or left front wheel on a Falcon... I know that for sure.....
  7. bulletproof1
    bulletproof1
    from tulsa okla
    i thought this was a joke .....
  8. propwash
    propwash
    from Las Vegas
    heck...just put a piece of tin around the 'wound' and a couple of small hose clamps...then solder it all. Impervious...and, you can always pinstripe the solder clump.
    dj
  9. 117harv
    117harv
    In one of the Munsters movies, Herman fixed a pie crust slick side wall blow out with an X of electical tape, and then continued on with the race:).
    That was in the movies, this is real life...REPLACE IT!!!
  10. duct tape wound and refill and post video of first panic stop ...
    ooops did i say that ...
    replace? asking was a joke right?
  11. oldolds
    oldolds
    If you have to ask this question, please take your car to a real mechanic. He should be able to fix it for less than $100. Unless he sees more bad lines. That price is including labor. Figuring a labor rate of $60/hr or less.
  12. FINKSTR
    FINKSTR
    Better to poor than dead!
  13. dallasdrifter
    dallasdrifter
    from dallas tx
    already bought 2 section's of length, bent them with a bender, hooked up the fittings, and bled the brakes. I had to ask because I have heard of people braze welding a section of copper pipe a bit bigger than the line over the pinch hole.
  14. gsport
    gsport
    solder??? why not just wrap it with a little duct tape....
