So-Cal Rear spring...
Discussion in 'The Hokey Ass Message Board' started by OCTANE ORPHAN, Jan 10, 2010.
  1. OCTANE ORPHAN
    OCTANE ORPHAN
    from Ohio
    I was just wondering if anyone has, or can get some measurements from one of the new So Cal rear springs... I know its 2 1/4 wide, But how tall and what does it measure eye to eye? Thanks
  2. OCTANE ORPHAN
    OCTANE ORPHAN
    from Ohio
    Nothing?? I think i just might have to grab one so the hamb has this info!!
  3. sota
    sota
    Give So-Cal a call they will tell you what you need to know.
  4. ratrod0
    ratrod0
    its the same thing as a 35 - 40 front spring. you but it on the back so the shackles dont hit your tires when you hit a bump. i think there spring eye to eye on the rearend goes 42 1/2 (check with them befor you weld ) if you use a 35 - 40 front spring 42 eye to eye on the rearend
  5. pasadenahotrod
    pasadenahotrod
    from Texas
    For what application?
  6. ratrod0
    ratrod0
    For the rear of a 32 and down may-be more. I used it on a 32 ford coupe
  7. hot rod pro
    hot rod pro
    from spring tx.
    i have one on a so-cal frame in my shop. mounted, from the bottom of the spring eye to the bottom of the center part of the spring it has an arch of 5.5". this is on there rear end and chassis sitting on tires and wheels. there is not a body on the chassis also.
    -danny
  8. Bib Overalls
    Bib Overalls
    I think the spring perch spacing is 44".
  9. VAPHEAD
    VAPHEAD
    I use the Posies AJ40NH spring.
    It is 44" on the hangers.
  10. fab32
    fab32
    They use a '40 front spring made by Eaton Spring in Detroit. Reverse eye.
    Frank
  11. VAPHEAD
    VAPHEAD
    I (for some reason) hate the term "'40 front spring."
    It ain't correct.
    A 1940 Ford front spring is only 2" wide for starters.
    People keep repeating it and it is almost a urban legend of sorts.
  12. EatonDetroitSpring
    EatonDetroitSpring
    Hi, we'd like to clear something up.
    When they is mentioned, I think you mean So-Cal. But Posies is mentioned in use by someone else, so I'm not quite sure which one this is a response to.
    Either way, Eaton Detroit Spring does not sell anything to either So-Cal or Posie's.
    We do manufacture 40" front springs with Reverse eyes, but any springs from So-Cal or Posie's are not ours.
