RTV Gas Seal?
Discussion in 'The Hokey Ass Message Board' started by C9, Jul 18, 2007.
  1. I have a good start on making some auminum flanges for an aluminum gas tank.
    The basics are, one flange inside and one outside with the filler plate/neck adapted to the outer flange with studs and nuts.
    The inside and outside flanges will be held together with a separate group of FH stainless allen 1/4-28's.
    I want to seal the thread area where the FH allens go through the outer flange, then the tank's upper surface and into the inner threaded flange's threaded (12) holes.
    The flanges proper will have a suitable gasket.
    Seems like there ought to be an RTV that will do the job.
    Recommendations?
  2. squirrel
    anything except rtv!
    used to be that Chevy used fiber washers on the sending unit screws.
  3. Notorious
    Notorious
    from NC
    I agree. RTV is much too often looked upon as a cure-all. It is not, by any means. It has it's proper uses but they and it's limitations are largely ignored all too often.
  4. I knew that RTV had it's problems around gasoline, but thought if it was used as a thread sealant it may work.
    So what should I use?
    Keeping in mind I want to be able to disassemble the flanges later on if necessary.
  5. as far as i know , the only stuff that will seal and hold up to gasoline is Permatex
    it's worked for me for 40+ years..and many others since 1909
  6. Silicone works great,until it comes in contact with gas.
    There should be some liquid Teflon sealer available.
  7. Hackerbilt
    Hackerbilt
    So if I read this correctly your just looking for something to prevent gas from "wicking" up the threads and giving off fumes?
    Wouldn't a properly fitted gasket "squish" enough to form a tight seal to the bolt shanks right as they come thru the tank...thus making additional sealing of the actual threads redundant?
    If your doubtful, could you add tight "O" rings around the threads of the machine screws or do you figure they would tear?
  8. squirrel
    a drop of oil would keep orings from tearing, most likely.
    or use Holley bowl screw gaskets
  9. Sam F.
    Sam F.
    RTV works GREAT!.....
    ,,,at stopping up your fuel filter and needle floats! :D
  10. Kustomz
    Kustomz
    Permatex Ultra Black works!
  11. Flat Ernie
    Flat Ernie
    Tech Editor
    I believe RTV is the bane of the true mechanic. It is an evil foisted upon us by OEMs in search of a cheaper way to do things.
    RTV Silicones jelly in the presence of petroleum products - gasoline nearly instantly, but even oil over a relatively short period of time.
    Use it near water only...and then as sparingly as you can.
    I'll second permatex #1 as the sealant of choice near gasoline - it won't fix leaks, but it would serve your purposes well.
  12. DrJ
    DrJ
    I'm thinking tank sealer or varnish might work.
    Anyone got an opinion on them?
  13. Mel
    Mel
    Seals All works great for anything that comes in contact with gas, water or oil. Depending on your application, this will prevent leaks or stop them quickly with great durability. Just don't heat this stuff or it's really difficult to remove...
    Here's a review on it....
    http://www.totalmotorcycle.com/reviews/SealAllGlueReview.htm
    FWIW, if you test this stuff out, you're only out $2 if you hate it and you'll probably find other uses for it.
  14. Flat Ernie
    Flat Ernie
    Tech Editor
    I've tried this stuff - it's garbage in my opinion. Others may have luck with it - tried to use it to seal up minor oozing around sending unit - no luck. Tried it around a filler neck seep - no luck. Garbage.
  15. tomslik
    tomslik
    windshield urethane works.....
    not sure you'll get the screws back out though...
  16. chopolds
    chopolds
    from howell, nj
    1. Kustom Painters
    I used to work at a major oil company research center, next to a refinery. To seal up stainless fittings, and other hard to seal joints, in the presence of gasoline, we used to use a product called "Gasoila". Never used anything better for this application. Hard to find, though.
  17. You'd think it would and apparently it does ok for some, but I think the problem I had with the leaking fuel cell and aluminum tank was that the inner ring with studs welded to it had several poor quality welds that allowed fuel to seep up the threads and out from under the washers on the bolts.
    Not to mention that two of the studs on the new aluminum tanks inner flange were welded in at an angle so not too many things will seal with an angled hold down stud.
    The studs are effectively 'under-water' when the filler neck is full and gas runs out pretty good.
    After the fuel level goes down, fuel sloshing around does the "wick-up" bit as HackerBill mentions.
    I thought of o-rings around the studs/bolts and it would be easy to machine a shallow step where they go, but I think using a double flange setup with sealant laden bolts into the lower flange will work better.
    That way, the filler neck's flange only has to seal against the outside tank flange for a good seal.
    Fwiw, the inner flange will be two piece and seal for a full 360 degrees.
    With a gasket, fuel shouldn't get near the filler flange/outer flange studs to leak.
    Just another one of the 'good ol daze' universal type parts that take some massaging to work right.
    Kinda what a great part of hot rodding was back in the day.
    A pair of good rat-tail files was on the workbench of every serious hot rodder I ever knew.
    I'll shoot some pics as I go and post it as a tech article.
    If it helps one person I'll be amply rewarded.
    Hell, if it works for me I'll be happy....:D
  18. http://www.gasoila.com/
  19. squirrel
    how about a sketch of the cross section of this thing? my imagination isn't working as well as it should be
  20. DrJ
    DrJ
    I didn't know this stuff was still made!
    IT's MARVELOUS!!!!
    I had some that I inherited from my Dad who I think inherited from his but it finally ran out and I haven't seen it since.
    The one I'm familiar with I think is the hard set.
    It was used for those problem areas n old carburetors that we figured would mever have to come apart again, by us anyway... ;)
    Get some...I'm going to.
  21. <TABLE id=table33 cellSpacing=0 cellPadding=0 width="100&#37;" bgColor=#cfdfd9 border=0><TBODY><TR><TD width="97%">
    [FONT=verdana,arial]Sealant Recommendation Chart
    Use the chart below to link to the correct sealant for your application
    [/FONT]
    [FONT=verdana,arial] ​
    [/FONT]</TD></TR><TR><TD width="100%" colSpan=2></TD></TR><TR><TD vAlign=top colSpan=2>[FONT=verdana,arial]
    <TABLE id=table34 cellSpacing=0 cellPadding=2 width="85%" border=0><TBODY><TR><TD vAlign=top align=middle width=222> </TD><TD vAlign=top align=middle bgColor=#b5cec5>[FONT=verdana,arial]Gasoila&#174;
    Soft-Set
    [/FONT]
    Hard-Set
    [/FONT]
    </TD><TD vAlign=top align=middle bgColor=#b5cec5>[FONT=verdana,arial]PLS&#174;2[/FONT]</TD><TD vAlign=top align=middle bgColor=#b5cec5>[FONT=verdana,arial]Gasoila&#174;
    100
    [/FONT]
    High-Fill
    (JC-30)
    [/FONT]
    -NT
    [/FONT]
    </TD><TD vAlign=top align=middle bgColor=#b5cec5>[FONT=verdana,arial]FasSeal
    -ATS&#8482;
    [/FONT]
    </TD></TR><TR><TD vAlign=top width=222>[FONT=verdana,arial]
    [FONT=verdana,arial]Acids, dilute
    [/FONT]
    [/FONT]</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD></TR><TR><TD vAlign=top width=222 bgColor=#c6d9d2>[FONT=verdana,arial]Acids, concentrate[/FONT]</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD></TR><TR><TD vAlign=top width=222>[FONT=verdana,arial]Air, compressed[/FONT]</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD></TR><TR><TD vAlign=top width=222 bgColor=#c6d9d2>[FONT=verdana,arial]Alcohol[/FONT]</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD></TR><TR><TD vAlign=top width=222>[FONT=verdana,arial]Ammonia, anhydrous[/FONT]</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD></TR><TR><TD vAlign=top width=222 bgColor=#c6d9d2>[FONT=verdana,arial]Ammonia, gaseous[/FONT]</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD></TR><TR><TD vAlign=top width=222>[FONT=verdana,arial]Ammonia, liquid[/FONT]</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD></TR><TR><TD vAlign=top width=222 bgColor=#c6d9d2>[FONT=verdana,arial]Aliphatic Solvents[/FONT]</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD></TR><TR><TD vAlign=top width=222>[FONT=verdana,arial]Aromatic Solvents[/FONT]</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9> </TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9> </TD></TR><TR><TD vAlign=top width=222 bgColor=#c6d9d2>[FONT=verdana,arial]Brine[/FONT]</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD></TR><TR><TD vAlign=top width=222>[FONT=verdana,arial]Butane[/FONT]</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD></TR><TR><TD vAlign=top width=222 bgColor=#c6d9d2>[FONT=verdana,arial]Caustic, dilute[/FONT]</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD></TR><TR><TD vAlign=top width=222>[FONT=verdana,arial]Caustic, concentrate[/FONT]</TD><TD vAlign=top align=middle bgColor=#cfdfd9> </TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9> </TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9> </TD><TD vAlign=top align=middle bgColor=#cfdfd9> </TD><TD vAlign=top align=middle bgColor=#cfdfd9> </TD></TR><TR><TD vAlign=top width=222 bgColor=#c6d9d2>[FONT=verdana,arial]Chlorinated Solvents[/FONT]</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD></TR><TR><TD vAlign=top width=222>[FONT=verdana,arial]Coal Tar[/FONT]</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9> </TD></TR><TR><TD vAlign=top width=222 bgColor=#c6d9d2>[FONT=verdana,arial]Cutting Oils[/FONT]</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD></TR><TR><TD vAlign=top width=222>[FONT=verdana,arial]Diesel Fuels[/FONT]</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9> </TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD></TR><TR><TD vAlign=top width=222 bgColor=#c6d9d2>[FONT=verdana,arial]Ethanol[/FONT]</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD></TR><TR><TD vAlign=top width=222>[FONT=verdana,arial]Ethylene glycol (anti-freeze)[/FONT]</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9> </TD></TR><TR><TD vAlign=top width=222 bgColor=#c6d9d2>[FONT=verdana,arial]Fatty acids & liquids[/FONT]</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD></TR><TR><TD vAlign=top width=222>[FONT=verdana,arial]Freon<SUP>TM</SUP>[/FONT]</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9> </TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9> </TD></TR><TR><TD vAlign=top width=222 bgColor=#c6d9d2>[FONT=verdana,arial]Gasahol (unleaded & 10% alcohol)[/FONT]</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD></TR><TR><TD vAlign=top width=222>[FONT=verdana,arial]Gasoline[/FONT]</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9> </TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD></TR><TR><TD vAlign=top width=222 bgColor=#c6d9d2>[FONT=verdana,arial]Glycerine[/FONT]</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD></TR><TR><TD vAlign=top width=222>[FONT=verdana,arial]Heating Oils[/FONT]</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9> </TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9> </TD></TR><TR><TD vAlign=top width=222 bgColor=#c6d9d2>[FONT=verdana,arial]Helium, gaseous[/FONT]</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD></TR><TR><TD vAlign=top width=222>[FONT=verdana,arial]Inert Gas[/FONT]</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9> </TD></TR><TR><TD vAlign=top width=222 bgColor=#c6d9d2>[FONT=verdana,arial]Jet Fuel[/FONT]</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD></TR><TR><TD vAlign=top width=222>[FONT=verdana,arial]Kerosene[/FONT]</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9> </TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD></TR><TR><TD vAlign=top width=222 bgColor=#c6d9d2>[FONT=verdana,arial]Ketones[/FONT]</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD></TR><TR><TD vAlign=top width=222>[FONT=verdana,arial]Liquified Petroleum gases (LPG)[/FONT]</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9> </TD></TR><TR><TD vAlign=top width=222 bgColor=#c6d9d2>[FONT=verdana,arial]Methanol[/FONT]</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD></TR><TR><TD vAlign=top width=222>[FONT=verdana,arial]Methyl Chloride[/FONT]</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9> </TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9> </TD></TR><TR><TD vAlign=top width=222 bgColor=#c6d9d2>[FONT=verdana,arial]Mineral Oils[/FONT]</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD></TR><TR><TD vAlign=top width=222>[FONT=verdana,arial]Naphthas[/FONT]</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l </TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9> </TD></TR><TR><TD vAlign=top width=222 bgColor=#c6d9d2>[FONT=verdana,arial]Natural Gas[/FONT]</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD></TR><TR><TD vAlign=top width=222>[FONT=verdana,arial]Nitrogen, gaseous[/FONT]</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9> </TD></TR><TR><TD vAlign=top width=222 bgColor=#c6d9d2>[FONT=verdana,arial]Petroleum Solvents[/FONT]</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD></TR><TR><TD vAlign=top width=222>[FONT=verdana,arial]Propane[/FONT]</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD></TR><TR><TD vAlign=top width=222 bgColor=#c6d9d2>[FONT=verdana,arial]Refrigerants[/FONT]</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD></TR><TR><TD vAlign=top width=222>[FONT=verdana,arial]Soap, liquid[/FONT]</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD></TR><TR><TD vAlign=top width=222 bgColor=#c6d9d2>[FONT=verdana,arial]Steam[/FONT]</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD></TR><TR><TD vAlign=top width=222>[FONT=verdana,arial]Toluene[/FONT]</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9> </TD><TD vAlign=top align=middle bgColor=#cfdfd9> </TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9> </TD></TR><TR><TD vAlign=top width=222 bgColor=#c6d9d2>[FONT=verdana,arial]Vegetable Oils[/FONT]</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD></TR><TR><TD vAlign=top width=222>[FONT=verdana,arial]Water (Hot or Cold)[/FONT]</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD><TD vAlign=top align=middle bgColor=#cfdfd9>l</TD></TR><TR><TD vAlign=top width=222 bgColor=#c6d9d2>[FONT=verdana,arial]Xylene[/FONT]</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD><TD vAlign=top align=middle bgColor=#c6d9d2>l</TD><TD vAlign=top align=middle bgColor=#c6d9d2> </TD></TR></TBODY></TABLE>
    <TABLE id=table35 cellSpacing=0 cellPadding=2 width="85%" border=0><TBODY><TR><TD vAlign=top align=middle width=222> </TD><TD vAlign=top align=middle width=82 bgColor=#b5cec5>[FONT=verdana,arial]Gasoila&#174;
    Soft-Set
    [/FONT]
    </TD><TD vAlign=top align=middle width=81 bgColor=#b5cec5>[FONT=verdana,arial]Gasoila&#174;
    Hard-Set
    [/FONT]
    </TD><TD vAlign=top align=middle width=59 bgColor=#b5cec5>[FONT=verdana,arial]PLS&#174;2[/FONT]</TD><TD vAlign=top align=middle width=81 bgColor=#b5cec5>[FONT=verdana,arial]Gasoila&#174;
    100
    [/FONT]
    High-Fill
    (JC-30)
    [/FONT]
    -NT
    [/FONT]
    </TD><TD vAlign=top align=middle width=72 bgColor=#b5cec5>[FONT=verdana,arial]FasSeal
    -ATS&#8482;
    [/FONT]
    </TD></TR></TBODY></TABLE>​
    [/FONT]</TD></TR></TBODY></TABLE>
