Residual Valve mounting position
Discussion in 'The Hokey Ass Message Board' started by 4gotn1, Mar 28, 2004.
  1. 4gotn1
    4gotn1
    Do residual valves have to be mounted horizontal or can they be vertical? Every application that I have seen recently shows them horizontal. Also I read somewhere that they need to be mounted no more than a foot from the master cylinder. Is that true?
  2. forsakenfew
    forsakenfew
    from seattle
    i just installed 2 willwood valves in the vertical position, about 6" from the master. works great. i don't recall the willwood directions mentioning anything about a horizontal/vertical preference.
  3. skipperman
    skipperman
    Vertical/horizontal ---no difference...and AS CLOSE to the master cyl. as possible ......
    jersey skip
  4. jerry
    jerry
    approx 74 chevy pu truck has the peoportioning valve mounted out in front of the radiator, about 4-5 feet from the master as the tubing routes.
    jerry
  5. scoop
    scoop
    Should the residual valve be before or after the proportioning valve?
  6. Snake9t9
    Snake9t9
    Found this diagram a while back, can't remember where, but I kept it. Maybe some of you guys could use it.
