Removing original underbody coat
Discussion in 'The Hokey Ass Message Board' started by Merc0Matic, Dec 19, 2014.
  1. Merc0Matic
    Merc0Matic
    from california
    I have a 1952 mercury and it came from the factory with a 1 inch hard almost rubber coat sprayed on the underside of the entire car and I'm wondering if anyone has had any experience with this stuff and if anyone knows a good way to get it off preferably down to bare metal because I have rust repair I need to do. Thanks
  2. 3wLarry
    3wLarry
    from Owasso, Ok
    start with an electric heat gun and a putty knife for the heavy stuff
    kidcampbell71 likes this.
  3. Merc0Matic
    Merc0Matic
    from california
  4. Slopok
    Slopok
    Wash with mineral spirits when the majority of it is off.
  5. buick47
    buick47
    from bc
    try one of those vibrating saw/chisel, I got one from home detpo and it rocks on any flat metal but it super noisy
    tb33anda3rd likes this.
  6. txturbo
    txturbo
    someone makes undercoating remover.....I saw it after I spent a lot of time removing some on an old panel truck. That stuff was rock hard. I used heat and a scraper. Worked best to have someone on the inside heating while I was on the undercoating side scraping.
  7. I did a lot of floor patch panels and I just sandblasted the floor areas that were going to be cut out until I got to solid metal.
    After the floors were solid again I scraped off anything that was loose then I bought a case of spray undercoat and sprayed the bare area and went back over everything underneath. HRP
  8. Ralphies54
    Ralphies54
    Faster yet with a Bernz-a-matic type torch with a small flame. Just warm up the area and a stiff puttyknife will peel the area clean in a jiffy. Wipe down with turpentine and your done.
  9. Finnrodder
    Finnrodder
    from Finland
    One vote for the heatgun and puttyknife too!
  10. Elbow grease, hate that job. What ever works, Some of mine chipped off cold with a putty knife.
  11. 19Fordy
    19Fordy
    I found it easier to use a 1/2 inch wide blade straight screwdriver and a ball peen hammer..
    First grind the blade of the screw driver to a chisel shape. so it cuts easier.
    It's a tedious, slow process.
  12. john walker
    john walker
    i have a pneumatic scaler tool that gets the rock hard stuff off nicely.
  13. rotorwrench
    rotorwrench
    The under coat is the likey reason you have corrosion. I have one 51 Merc with undercoat and one without that lived their life in the same part of the world. The one without has mostly surface rust. The one with has major cancer. I would prime the area well and put the sound deadener inside the car instead of outside.
  14. saltflats
    saltflats
    from Missouri
    I took a wood chisel and ground a radius on the edge and it works real well with the radius the corners will not dig in and works on most any contours. P1010031.JPG
  15. slammed
    slammed
    Some form's of undercoat will lift off w/an quality paint stripper, followed w/fresh Scotch Brite pads dipped in lacquer thinner.
  16. junk
    junk
    Heat gun putty knife.
  17. oldolds
    oldolds
    I have used all the above methods. Each one works. Some work better on one job than another. I know some people will not like this idea, but get a pump up garden sprayer and try spraying a bit of kerosene or diesel fuel on it. Sometimes it will soften it enough to scrape off easy. There is no magic solution. Elbow grease works best.
