Technical power steering on a f350
Discussion in 'The Hokey Ass Message Board' started by 1955 f350, Sep 1, 2014.
  1. 1955 f350
    1955 f350
    I found a steering box that will work on a f100 will it fit a f350 the only thing is the drag link is smaller just use a a hot rod now thanks
  2. willymakeit
    willymakeit
    I know we used a ton non power box on F100's for less steering effort. One more turn lock to lock. Should work.
    What kind of box is it?
  3. 1955 f350
    1955 f350
    trying to use a Toyota box they got a kit made for the f-1 and f100
  4. Mr48chev
    1. F-350 is a one ton by the way. 55 F350 there are some slave cylinder power assist setups out there but I have no idea of where to find one. Even though 539.00 sounds a bit spendy for the kit 53Olderthanme suggested it may be well worth it in cutting down on headaches on the install and on down the road.
  5. willymakeit
    willymakeit
    I have no experience with the Toyota box, but I know everyone likes them. I' ve been using Saginaw cross steering on the last 3 we built over 30 yrs. No issues.
    You shouldn't have any issues.
  6. Mark T
    Mark T
    Take a look at the power steering box from a 1999-2004 Jeep Grand Cherokee, should be easy enough to adapt.
