Man-A-Fre COMPLETE "American Graffiti" 4-carb set-up for small-block Chevy. (Chevrolet 327). Has correct Rochester 2CG 1957-58 Oldsmobile Tri-Power carbs, modified by Man-A-Fre. Tag number 7012450, very good used carbs, tight shafts, no wear evident. Correct float angles, throttle-shaft linkages modified by Man-A-Fre, with 0.010" wires in accelerator pump discharge nozzles to atomize mix. Leather accelerator pumps still working, smooth linkage, original red hand-painted base plates. This is not the usual pieced-together hodge-podge found at swap meets. This is Man-A-Fre original, correct and in excellent condition, in custom wooden crate for safe transport. $1,250.00 plus shipping cost. USPS Postal Money Order or CASH if you come pick it up. Central Iowa. call Roger at 515-233-2076 for questions.
