lower a 1950 Ford
Discussion in 'The Hokey Ass Message Board' started by tedster, Mar 20, 2005.
  1. ham-boned-ford
    ham-boned-ford
    That is one bad ass ride love the vicky's roofline!
  2. cant wait to see the tech by Tuck. I got a more-door in the works that needs a serious height adjustment, unless I get a 2 door before that...the 4 door will them become my "more" parts car for the 2 door. :)
  3. I used the jamco 3 inch lowered springs on my 50 shoe box and it rides great. When springs settle from riding on then it looks nice and low. Will post picture when I can find it.Kit come with springs shocks and rubber bushings for front sway bar.
  4. FiftyThreeFord
    FiftyThreeFord
    from USA
    this thread is helpful.., i like seeing everyone's point of view. i'm new here, and to the rod / car scene, but i got a 53 ford.., i'm going to cut 1.25 coil in the front and 3 or 4 inch blocks in the back. (pay no attention to how low my profile picture sits.., i'm a photoshop geek)
  5. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    Im doing front lowering blocks today for my 51. They are a pain, but very worth it and it retains stock ride which is nice. I have done a few sets already, 1 being my 50 Merc and I would never look back. 1 1/2" either 1/4" wall square tube or solid aluminum from any supply store.
  6. fuel pump
    fuel pump
    from Caro,MI
    Here is my ragtop with the fatman dropped spindels and jamco springs, shocks and sway bars. It's low enough for Michigan roads and the ride is great.
  7. RenoRat
    RenoRat
    from Oxnard,Ca
    i dropped mine by using the fenton front lowering blocks that were menchoned earlier as well as 4 in blocks rides well but i had to raise the floor!!
  8. zcwagner
    zcwagner
    from Tucson
    6 years later Im reading the same posts and loving it.
  9. deuce1348
    deuce1348
    I'm new to this forum so hopefully I won't sound like an idiot but I actually am an idiot so I guess it all works out lol. Have a 50 ford sedan I want to lower but unsure how much trouble the front will be? I bought Aerostar coils with 5821 shocks as well as new king pins. Plan to flip the spindles upside down then switch side to side with new kingpins. Will I need to buy drop steering arms to make this work or can I get by with heating and bending them? If anybody has more knowledge doing this please let me know or any problems I may run into like bushings or alignment issues I would greatly appreciate it!!! I don't have the cash to sink into the jamco spindles and just trying to get it do as cheap as possible but at same time be safe for my family to ride. Also this car belonged to a Vietnam vet that was KIA back in 1968 so I plan on making this car a tribute to him and all the falling brave men and women we lost in Vietnam. Thanks for your response!!!!
  10. Mudslinger
    Mudslinger
    Heres mine with one coil cut out of the front and 4" blocks and one leaf removed rear.
    The front I bottomd out one time on the bump stops.
    I would like it lower when I get it finished.
    I might buy new dearched springs and maybe try a half coil more up front.
  11. I don't know if you guys spotted this but this thread was started 8 years ago. Tuck was going to do a "how-to" based on the job I did on my 49 coupe when I flipped the spindle uprights. Don't know if he ever did it. Yeah, there is some heating and bending to do and if you're queasy about this, don't attempt it....too much heat can damage the metal.
    I also cut 1.5 loops off each front coil, had to heat and bend the steering arms down and heat the ends of them to bend them back up, 180 degrees to the ground.
    I also mounted a 1.25" trans-am/Z-28 stabilizer bar to the lower control arms.
    With the heated steering arms [made the arms shorter when bent] and the stiff stabilizer bar, this coupe rode a little stiff [loved it!] and went round corners like a slot car.
    BTW, I used a SBC in my car..sat the engine up a little higher than most guys to clear the tie rod with the oil pan.....worked great but as low as my car sat, I had to re-do the tranny hump and driveshaft hump for clearance...and a mid 60s comet/fairlane gas tank fixed my rusty trunk floor and with it's side-mounted filler tube, a guy can reuse the original fuel filler, using a custon bent pipe.
  12. tedster
    tedster
    Well this is depressing. Seeing as I was the OP on this and reminding me I have had my 50 for 8 years and it still is not done. Crap.
  13. Mike51Merc
    Mike51Merc
    Tedster,
    For about $60 get yourself a set of 1990 Ford Aerostar front coil springs.
  14. tedster
    tedster
    I ended up with Fatman dropped uprights and dropped steering arms and Aerostar springs.
  15. happy hoppy
    happy hoppy
    Front, Fatman dropped uprights, steering arms and aerostar coils.
    Rear, "4 inch blocks and 2 leaves removed from rear spring pack.
    Your rear axle will hit the frame at this height. Your stock drive shaft tunnel will rub the drive shaft in the rear seat area. The rear shocks are almost level with the ground at this height, I relocated my upper shock mount to correct this and improve the ride.
    I also installed a C notch in the rear frame in anticipation of air bags, maybe.
    maybe not.
  16. Mudslinger
    Mudslinger
    Theres been a ton of old posts popping back up.
    Dont feel bad tedster im in the same boat. I chopped mine about three years ago and yanked the engine and trans. I just found the replacement trans a few days ago and cant wait on warm weather to start back on it.
  17. deuce1348
    deuce1348
    Thanks for the great advise guys! Like I said I'm new to lowering cars and this info was really helpful. I just need to save for the dropped spindles and steering arms. I was hoping I could just buy the steering arms and flip the spindles due to money tight lol. Thanks everybody!!!!
  18. olskl_dave
    olskl_dave
    Hey , can anyone tell me the size of the lug that l need to suit my shoebox rear (spring / housing).
    In Australia we cannot buy blocks to suit '50 Ford. l was hoping to find something that matches.
    Regards Dave.
  19. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Dave- that centering pin- if you're making lowering blocks you can just use a 9/16" bolt and round it off in the grinder- then bolt it into your block before you weld the ends assuming you're using square tubing for the drop- we used to make drop blocks all the time like that-
  20. olskl_dave
    olskl_dave
    Cool.
    Thanks for that Tuck, l didn't want to pull her down untill l was ready to go...
    Regards Dave.
  21. Kelly Burns
    Kelly Burns
    Lets revive this thread!
    I got our lowers off and the shock and springs out last night. Only had one cotter pin that gave me a bit of a fit. I cut 1-1/2 coils off and began "splitting" the lower control arms. I was using a cut off wheel, and was worried about getting into the spring plate, when the cut off wheel broke in half, that's when I decided to drill them. I'm going to use a little larger diameter grade 8 bolt than the rivet was and fab my own 1" spacers.
    I'm of the same state of mind as @50Fraud that the limit is probably is cutting 2 coils, so I may go after 1/2 coil more tonight, our car sat a little high to begin with I think. My original thought was 1-1/2 coils is roughly 3" and I could buy the 3" lowered shocks and do the 1" spacer, yielding a 4" drop.
    I was going to fab my own rear blocks, but with some of the prices I'm seeing, I may just buy a set, if I don't have material laying around.
