Priorities have changed, and it looks like it will be years before I can get back on this project. I'd rather see it finished and enjoyed than have it sit in the corner. Specs: -based off an early model A frame, kicked up in rear -28-29 model A grill and cowl, 25 Buick tub, door openings same as 28-29 model A coupe -32 Ford axle 3" drop by Titus, Model A spring with main reversed and leafs taken out, F100 brakes to go with it, split Model A bones, ;48 merc rear axle, model A rear leaf with main reversed and leafs taken out. -59AB engine thats had work done to it decaded ago, merc crank, ported and relieved, full race cam, I have a full set of Isky valve springs and valves to go with it, Speed-o-motive pistons, bored out to 276ci, Fenton dual carb intake, 2 stromburg carbs for rebuildable cores. -39 toploader stuffed with 25 tooth Zephyr gears -46 ford steering column -4 16" wire wheels, brand new Cokers all around Its pretty close. I stalled on it last summer and it has sat since. Had a second child born 2 months ago, and time is tight. Also the interest is no longer there. To finish car needs radiator modified for flathead. Engine needs to be rebuilt, steering, brakes, paint, and electrical. Will not part out. Please dont ask. Here is the build thread http://www.jalopyjournal.com/forum/...ngs-lets-see-if-i-can-finish-this-one.704931/ I will post current pics shortly.
Ok rock bottom price $3500. If I don't get that ill part it out and most likely get more out of it Posted using the Full Custom H.A.M.B. App!
