to fix your broken photo link if you used your HAMB photo album as your host before the latest reformatting open your thread you want to fix in two tabs one will be your reference thread one will be the one you fix in the one you are to fix click EDIT at the bottom of the individual post erase the x and replace with: [GALLERY=media, insert picture number][/GALLERY] go to the tab with your reference thread right click on the same x chose properties copy the number after the second equal sign in the address go to the tab with the thread you want to fix replace "insert picture number" with the number you have copied repeat for all pictures in the post when you finish fixing that post save changes and go on to the next. repeat for every picture you want to relink in the thread.
it should be possible to write a simple algorithm to do this on a global scale or at least forum scale..
