How much fluid does a Turbo 350 hold?
Discussion in 'The Hokey Ass Message Board' started by Rocket88, Mar 9, 2005.
  1. Rocket88
    Rocket88
    I'm having a brain fart here.
    I've got a new converter (prefilled it with a quart and a half) I also pulled the pan and installed a new filter.
    How much more to fill it up?
  2. manyolcars
    manyolcars
    Isnt it 10 pints? including the converter? Or is that quarts? :)
  3. a t-350 COMPLETELY dry will take about 12 quarts....but you probabailly still have quite a bit still in it , even with the filter change and the quart in the convertor , i'll say around 7 quarts..then see where you are after you fire up the motor
  4. Should be 12, hahahahhhhhahahaha but 10 was more than I needed after a rebuild on mine:eek:
