Technical how do I identify the year of a Model T?
Discussion in 'Traditional Hot Rods' started by Paul, Oct 23, 2014.
  1. Paul
    Paul
    Editor
    I picked up a pile of parts the other day, not sure what years they come from, is there a source for identifing year by simple clues or body dimensions?
    its a roadster mid teens, turtle deck has rear corners factory spot welded in, windshield frame has provisions for cowl lamps to bolt on, small firewall opening looks like it may have had a wood firewall..
    I'll try to get some pictures loaded up..
  2. steel rebel
    steel rebel
    Load the photos and we can tell you. Not exactly but pretty close.
  3. Ric Dean
    Ric Dean
    from Central NY
    .. I found a rough T Roadster Body that meets that description and I determined it to be a 1914. Get a body parts catalog that will help; + you could post some photos.
  4. Paul
    Paul
    Editor
    only pictures I have with me:
  5. That is a small cowl T, so 18-22 I belive?
  6. 23-25 looked just like it but had a larger firewall
  7. need louvers ?
    need louvers ?
    Yup, Chris nailed it! Technically it's '17- early '22.
  8. I stand corrected, thanks!
  9. That is also a 17-22 complete windshield laying on the trailer. Pre 17 was round on all 4 corners and post 22 was square on all 4 corners.
    The Wizzard
  10. Paul
    Paul
    Editor
    Excellent info guys,
    Sorry I don't have pictures of the turtle deck but appears to be a bit narrower than the reveal on the back panel and the rear corners are spot tacked in, I have the feeling it may be earlier than the body. Enough clues there or do you need pictures or dimensions to accurately date it too?
  11. Bruce Lancaster
    Bruce Lancaster
    bct likes this.
  12. Technically, the "high cowl" didn't make it into production until mid-1923; very close to the 1924 model year. It's a moot point though, the car in question has straight windshield stanchions with integral mounts for the side lamps; that makes it a 1917-early 1920 (ish) model.
  13. Cut it in half and count the rings... oh, sorry- that's for a Chevy :D
    volvobrynk likes this.
  14. Paul
    Paul
    Editor
    Reads like I have a '14-'16 turtle deck.
    Thanks again!
  15. steel rebel
    steel rebel
    I always thought that that cowl design started in'15 and before it was just flat.
  16. Indeed, but that little half-moon shape in the cowl top gives its identity away as a black radiator car. Ford had to move the support rod a little higher beginning in '17 and the result is that little half-circle.
  17. Nice! wondered who bought that. It was a good price!
  18. Paul
    Paul
    Editor
    I do believe it's salvageable. .
    Been looking at pictures for inspiration.. like I have time for that :)
  19. von Dyck
    von Dyck
    That body has weathered incredibly well. New wood is available from Snyder's, Brattons, and others, but is pricey! Mine is all steel reinforced (3/4" square tubing - easy stuff to shape).
  20. steel rebel
    steel rebel
    Wow learn something every day. I guess mine is a 17 or newer. I just looked at the early photos of the body I bought and it has that notch in the flat part that the firewall connects to.
  21. 29pu
    29pu
    Turtle decks are almost the same for the low style.1913`s had square corners.14 to around 20 had round handles and round corners.The ones later low decks had flat handles.The deck of the body is wider and longer than the turtle deck.Sure is a nice body and it has the kinda hard to find moulding pieces for the back of the body.Good find.
  22. Paul
    Paul
    Editor
    It came with a full set of wood blue prints,
    but I will likely use steel too.
    here is the turtle deck
