I've got a couple Holley 2 bbls. but not sure what hey are. I have a book that says; 350cfm has 1.375 throttle bores 500cfm has 1.69 throttle bores The 2 I have, have 1.48 throttle bores. Both have 7508-1 on the choke horn. I was told the one with the little red triangle was a 500 w/electric choke when I bought it. The other I was told "might be" a 350 mech. choke. It was pulled off a Pinto motor. Here are some pictures. Let me know if you need more info. Thanks in advance....
http://www.carburetion.com/CarbID/HolleyID.htm best I know of for id purposes and I found this, looks like you're not the first to wonder http://www.mercurycougar.net/forums/showthread.php?t=6856
7448 350 cfm also has 1/4 thread on air cleaner stud.. 4412 is 500 cfm 5/16 thread air cleaner bolt..
hey guys, sorry i missed this thread. i have an illustrated parts and spec book from holley. lists all holley carbs by #.. this # 7508 is universal replacement ford 61 to 74 ,221 cid to 429, all trans ( see kickdown linkage in pics) no cfm listed, but the throttle bores work out to 425 cfm or so.. i will be glad to help id any holley carbs...start a thread or pm me. dave lewis
