Hot Rods Help sizing wheels and tires
Discussion in 'The Hokey Ass Message Board' started by 53woody, Nov 28, 2014.
  1. 53woody
    53woody
    I'm trying to figure out the wheels and tires on the black roadster, I love the way it looks. 021310CAReShow049-vi.jpg
    I want to run wire wheels on my 28 roadster but 16" look to big and I have a clearance problem. Does it make sense to run original 16"wires on the back and 14 or 15 repo's on the front, or should I just run repo's all around. What do you think. Bruce DSCF1835.JPG DSCF1836.JPG
  2. scrap metal 48
    scrap metal 48
    From your pics, the front tires look to big.. If they were 4.50's, 5.00's or 5.50's I think your clearance issues would be fine with 16" wheels...
  3. missysdad1
    missysdad1
    Agree. Keep in mind also that the same size tire will look different on your A than it does on the Deuce you show as an example. It's a good idea to use the same make/year as an example to get a more accurate idea of what a specific tire size will look like on your car. It's my opinion that A's look better proportioned with tires a size or two smaller than Deuces because they are smaller cars.
  4. Model A Gomez
    Model A Gomez
    My avatar has 16 inch wires with 7:00 on the rear and 5:50 on the front. The front tires always rubbed on the inside of the fenders at full turn. Had 4" dropped axle that was 47" wide, building another Model A with a 48" wide axle, hoping to avoid the problem.
  5. Need a shorter front tire and refitting of the front running board brackets.
  6. AVater
    AVater
    1. Connecticut HAMB'ers
    Here's a my Avatar with 750 x 16 on 5 inch rims in the back and 600 x 16 on 4 inch rims in the front.
    Chassis z'ed and reverse eye spring on the back. Pretty close back there but nothing hits/rubs. Front fenders ride with the wheels--so not much help there.
