Projects Frame and chassis paint
Discussion in 'Traditional Hot Rods' started by firerod, Aug 27, 2014.
  1. firerod
    firerod
    from Colorado
    I am getting ready to paint my sandblasted frame. I would like a semi gloss finish to look like a old original faded frame. Any ideas on primers or paints? A search pulled up Rustoleum, Eastwood, Bill Hersch. Which will be best? Thanks.
  2. mikhett
    mikhett
    from jackson nj
    I did my 62 galaxies and 56 fair lane Victoria with SPI EPOXY PRIMER I SPRAYED WITH A 1.4 TIP BUT U CAN BRUSH IT ON ALSO.CAME OUT GREAT.
  3. millersgarage
    millersgarage
    Use real automotive paint. Just have it mixed with a flattening agent to about 70%.
  4. blue 49
    blue 49
    from Iowa
    After blasting, I sprayed mine with self etching primer followed by John Blitz Black with hardener. 6 or 7 years later, it still looks good. I'm happy with it.
    Blue
  5. scott51
    scott51
    I'd recommend a decent 2K acrylic urethane, the kind of product typically used on truck chassis and heavy machinery.
    This is what I used on mine after blasting http://www.resene.co.nz/automotive/technical/Acrythane_TDS.pdf
    simple systems, very economical and really bullet proof (it laughed at the brake fluid I spilt all over it last weekend). Tends to have a factory looking dull semi-gloss finish, should get your blaster to hose it on once he's done.
  6. Sand blasted then sprayed with KBS . It's hard as nails .
  7. kracker36
    kracker36
    I like polane t industrial enamel by sherwin williams. It is very easy to use but requires a catalyst. I feel that it is the perfect coating for frames and chassis parts. Super tough and does not build and become too thick
  8. I've been experimenting with an asphaltum-based paint (similar to what Henry put on the Model A) - so far, I dig it. It stinks to high heaven and goes on super thin - but has the perfect 'eggshell' sheen.
    Most over the counter 'black' paint looks too blue or green to my eye - or ends up looking 'milky' (Rustoleum). Asphaltum is a rich black-brown. I can get some pics if you're interested.
  9. outlaw1949
    outlaw1949
    Most over the counter 'black' paint looks too blue or green to my eye - or ends up looking 'milky' (Rustoleum). Asphaltum is a rich black-brown. I can get some pics if you're interested.[/QUOTE]
    I would like to see some
  10. firerod
    firerod
    from Colorado
    gwhite, Yes I would like to see some pictures. Where do you get this paint? Do you have to prime it first?
  11. joel
    joel
    I used PPG Pithane with hardener. The gloss is very low and it fills imperfections well. It's made for industrial iron, bridges,etc.
  12. gearheadbill
    gearheadbill
    Yes please
  13. Cool, tell ya what, I'll do 4 samples, because application method and prep both seem to make a bit of a difference;
    1 sprayed on bare metal (no primer)
    1 brushed on bare metal
    1 sprayed on primed metal
    1 brushed on primed metal
    Give me a week or so and I'll get pics posted up.
  14. joeycarpunk
    joeycarpunk
    from MN,USA
    I've been using a 2 part urethane sold by Diamond Vogle Paints that's semi gloss and tough as nails. Holds up better then any factory-type chassis black I've used.
  15. StrickV8
    StrickV8
    gwhite - have you been able to complete the samples? like others, would be interested in seeing this. thx.
  16. jcmarz
    jcmarz
    from Chino, Ca
    I used black engine paint. Not too dull and not too shiny, it's just right.
  17. texkbc
    texkbc
    I used POR15 on this one 10511345_647778261987113_6765748176119660991_n.jpg 10407468_648253295272943_3134193026184385205_n.jpg
  18. Canuck
    Canuck
    PPG DP40LF on a sandblasted base, followed by satin Bernardo Urethane. Black, black, just a bit of a sheen.
    Canuck
  19. Not yet...will get to it soon; between family/work commitments and breaking my tailbone, it honestly hasn't been on my radar. Hopefully I can get to it soon!
  20. StrickV8
    StrickV8
    no problem! you have your priorities in order...hate hearing about the tailbone. take it easy.
