I have a '52 331 going in my '33 Plymouth coupe with the same tranny adapter to a LaSalle tranny. My engines is still stock though, with the exception of a '54 4bbl intake and headers. Cool stuff ya got there! Dave
hemis came with dual springs, where you said this was raced, probably not the stock ones now. OEM push rods weren't adjustable, no need with OEM hyd cam. Put "Hemi Tech Index" in 'search" & start reading!
Yep, those are our valve covers with the optional finned aluminum spark plug wire covers and they're on backwards The SP covers overhang the valve covers to allow the spark plus wires to exit - unless you have a fancy timing cover mounted distributor! Dennis
Hi there you have a real pearler here, Edelbrock X3 intake with 6x2 carbs, Obrein Trucker rocker covers, looks to be Jahn's pistons, have a catalouge for the Jahn's pistons so could find a part# for ya, Largon front cover is a first for me, havn't seen one of these, so maybe very rare, adjustable push rods are aftermarket, piston compression will be in my catalouge, 51-53 had small 1 3/4 valves and small ports, 54 was the first to have large ports, also 51-53 had small ports in manifold, so 54 intake manifolds very hard to find and you may want to upgrade to 54 heads with large valves and ports. 51-54 had long snout cam, later motors had standard small block type cam snout and timing gears, early hemi had a larger key way in crank and lower timing gear, can use s/b Chrysler, but there are two type of s/b Chrysler timing gears, I think they use earlier set? will check my notes, you have to widen s/b Chrysler lower gear key way a little! What rocker gear does this motor run? You can post a photo if you like, watch 51-53 Chrysler cranks as the early transmission shared the engine oil by way of oil passage out thru crank shaft to flywheel flange! They had a clutched type of automatic gearbox, clutch to start off in first gear, shift with no clutch to second gear! been doing hemi's for 30 years, have forgotten somethings, so have to research some things in my notes, if you need any more info, just ask, were all here to help ya out! Bretto
Modified crossram for 2 x extra carbs Jabsco self-priming marine pump Looks to be a 59 Ford Fairlane wheel minus centre crest Could be a 41-56 Packard going by Masters Parts catalogues with that style of webbing and early Ford style axle ends. Centre is held in with 9 x studs. There are clearance notches in the housing face for crown wheel clearance. Circa 1955 Packard appeared to change to a Salisbury housing with no removable centre and a shared manual with Studebaker. There were other models with axles that came with conventional flanges for wheel to bolt to.
