I found this here (full article): http://blogs.hotrod.com/6677067/mis...-order-for-ford-chevy-hemi-engines/index.html ~Jason
I aways thought it was kind of interesting that the 18436572 and Fords 15426378 firing orders are actually the same, just numbered differently. That is, if you brought Fords number 5 cylinder TDC on compression and wired it like a GM/Chrysler it would be right. Or for you Ford guys, vice versa. Larry T
It's showing the 401-425 Nailhead distributors in the front, wrong! The 300’s were up front but not considered a true nailhead.
This showed up a while back and the same mistakes were recognized. It was suggested that some companies may 'make mistakes' to identify thier own work for copyright reasons. Who knows.. Get a specific manual and you might be better off. Jeff
I don't have easy access to my books right now, but as I recall, the nailhead #1 cylinder is the front one on the passenger's side, isn't it?
Nailheads all(264-322-364-401-425) have the same firing order-12784563 but #1 is on the right bank and as stated the dist is in the rear.
Damn, there's only 4 cylinders on a VW aircooled engine, and while they got the firing order right (1-4-3-2), they blew it with the #1 and #2 cylinder....#1 is closest to the front, right across from #3 Front of car #3 #1 #4 #2 ..at least the couple hundred I've worked on, or owned...
Yep, I done printed it out cause I didnt look at it. I just ASSumed it was correct. You know what that gets me.............
WTF, the VW is wrong too. OOps, Oldguy, I hadn't read your post. Guess you would know whether the Vdub was right or not!! How 'ya been?
