chevy turbo 350 problems.. any one else ever have this prob?
Discussion in 'The Hokey Ass Message Board' started by sawzall, Mar 29, 2004.
  1. sawzall
    sawzall
    last night the wife and I went to pickup my 40 from storage.. During the winters when I am thrashing on other cars I store the car in my buddys garage thats about an hour away from home
    The car started right up and I backed out of his garage with no problems. as I was leaving my buddys place it was running great.. I wasnt in any hurry to get home and it had been quite awhile since I had driven the car so I was babying it..
    I drove about 1/2 mile to a gas station to put air in the tires. then drove about 4 more miles before I had to stop at a traffic light..
    then it happened.. as the light went green i put my foot down and nothin happened..no forward motion at all. luckily I was able to push the car into another gas station and called a coworker to help me pull it to his house..
    anyhow.. when I checked the tansmission dip stick I wasnt completely full of fluid, but it wasnt in the FILL ME NOW area either..
    has anyone ever had a similar problem?? if so what was the cause?
    I searched old posts with no luck.. i cant believe i could have burnt it up..
    fwiw I had the trans rebuilt by a local shop less than 9 months ago.. (granted I did put 15000 miles on the car since then 10,000 of them pulling a camp trailer) but gee wiz..
    at least this didnt happen in the middle of washington state or 1/2 way home from florida last fall..
    anyhow anybody got some tips to share? thanks in advance
    sawzall
  2. plmczy
    plmczy
    Maybe the fluid pick up clogged up? Smell the fluid on the dipstick, that will tell ya if it's burnt or not. Also if the fluid is black and not a nice red color will also tell ya. later plmczy
  3. Missing Link
    Missing Link
    uh oh. That's not good. Take a look at the modulator, or possibly just replace it. (Not the T37 Space Modulator, the vacuum modulator on the side of the trans.) It's been a while since I dealt with a th350 but that is a starting point. One more thing to consider is that if the car sat all winter without being run, ATF has a tendency to become like varnish. It could possibly just need a fluid and filter change. Keep me posted, dude.
  4. Fat Hack
    Fat Hack
    from Detroit
    Had that happen a couple of times.
    Once was way up north in Canada...600 miles from home! Grandpa said "Just give 'er lots gas and hold the brake once in a while!". It worked...the trans barely moved, then slipped some, then BANG...back to working!
    He said that dirt can block a passage, and that you can usually "blow it out" by upping the pressure a bit! Sounds caveman stupid, but it's worked for me on two or three occasions!
    Also, after extended storage, your converter drains back into the trans...you may have air trapped in the system that just needs to 'burp' itself out.
    GM auto trannys can handle ANYTHING...I've run them out of fluid, overheated them, abused the shit of of them, and only had ONE fail...and that was a TH250 Metric in a Monte Carlo that survived three years of bracket racing, so it didn't owe me a dime!
  5. Rocky
    Rocky
    Classified Editor
    Happened to my wife when she borrowed my pickup to go pickup some carpet. Mine got just low enough to injest a little air...mixed with the nasty old fluid and it came puking up the dipstick tube as a really un-appetizing brownish foam! The little truck came coasting to the side of the road and she started burning up her cell phone. 3 quarts later, it was back to normal again.
  6. zman
    zman
    from Garner, NC
    I would check the fluid and filter first, the modulator. Doesn't sound like it's anything really weird. Though I did have a dynaflow that would puke a quart every three weeks or so then was fine for a while, kinda like a cat with a hairball.
  7. lesabre59
    lesabre59
    I had the same problem until I ran an external trans fluid cooler..never had another problm since.
  8. sawzall this is a very good question. I also have had some weird shit going on with my Chevy Turbo 350. Mine does fine as long as I'm moving but if I sit very long in one place it starts burping fluid out of the dipstick and rear seal. I have been driving the car for years and this just started in October of last year. I do have a external cooler but have been thinking I might need one with a fan on it. Where do you guys usual mount your cooler? Mine is on the front of my radiator.
  9. For you all that had or have problems, how old are your trannys? We have a th350 out of a 77 nova and havent had a problem, but maybe this can be a warning for the future [​IMG]
  10. you have wear particles /sediment settled in the bottom of pan blocking the intake of the pickup-change the filter- wash the pan out and drive another two years!
  11. Sam F.
    Sam F.
    i havent had that problem..but i have had a problem were the one in my 56 likes to THOW UP all over the floor every once in a while,,mostly when i pull it out,..then pull it back in the garage, its fine if i drive it,,but its weird and messy
  12. sawzall
    sawzall
    Zman how to I check the modulator??
    Lesabre I do run an external cooler.. Its in front of the radiator and it’s the largest you can buy.. no fan though.
    Buford T
    this is a mid 80’s gm trans that I had rebuilt this time last year. Just before we took the car out west.. FWIW I had a turbo 350 out of a 77 nova that was around forever.. I just sold it on ebay last week and the guy picked it up at 10 am Sunday morning.. I went to fetch the car at noon. Perfect timing as always…
    Choprods.. I am praying your right. I’d be thrilled to swap in a filter tomorrow and drive it again Friday..
    Oh did I mention that the car is scheduled to appear at an “event” this Friday.. If the trans is in fact “toast” I’ll be going kamikaze on it later this week..
    Thanks for all the help thus far. You guys are great…
  13. also[my luck] -you could have debris from any rubber hose connections in trans lines if they are not all steel.........hope that isnt the cause....... [​IMG]
  14. Maybe you all can help me too, in this vein of TH350 problems...
    I have an '85 Chevy Scottsdale parts chaser pickup. The TH350 has seen better days apparently...She runs fine when going forward, but reverse is M.I.A. unless everything is "warmed up". The trans seems to be saying (after I put it in reverse) "OH, YOU WANT TO GO BACKWARDS, HMMM, Lemmie Think!...and THEN after more than a few seconds it goes into reverse...but slips if I give it gas. Fluid is up to snuff, nice red color, doesn't smell burnt. It's even worse when cold... When it's butt cold out, I have to wait at least 30+ seconds while revving the motor before it shifts into reverse. If it's some sort of early warning sign/adjustment, I'd like to hear it; if the trans is shot, let me know... [​IMG] The truck is for sale for the right price, BTW. It will be on E-Gay soon if not. Too many "projects".
  15. Fat Hack
    Fat Hack
    from Detroit
    Kevin...one of my old Nova did that when it got low on fluid. If it was warm, reverse engaged pretty quick. If not...you waited till it felt like going in!
    You sure about the fluid level?
    Throw an extra quart in and see what happens...it'll puke out whatever it doesn't want!
  16. put a half pint of DOT brake fluid in it...whatDhell-its broke anyhow........might help
  17. Django
    Django
    Jeff, I am also thinking you need to change the filter. Guys, would a modulator problem not let it engage at all? That doesn't seem right. The modulator allows the tranny to shift when the pressure is built up, but to not move at all... that's something different. When I changed the modulator on the '46, I had to drop the tranny down and then you can have it out in 5 minutes. If the gears on the modulator cam are worn, you have to replace it, but sometimes it's hard to tell.
  18. Fat Hack
    Fat Hack
    from Detroit
    Yeah, a modulator problem usually affects shifting. When I first got my old Pontiac on the road, I freaked out because it wouldn't shift out of low gear on the very first test run around the block.
    Looking it over back in the driveway, I found that I had reached down and stuck the vacuum hose for the modulator onto the adjustment screw rather than onto the nipple it was supposed to go onto. A quick an easy fix!
    (That car had an aftermarket adjustable modulator)
    You can check a modulator with a hand-held vacuum pump. It should hold vacuum. If it doesn't...or if it sucks out tranny fluid, it needs to be replaced!!
  19. sawzall
    sawzall
    well I got the car home last night.. I'll try to get the pan off tonight and see whats goin on in there..
    thanks again to everyone for all the tips.. I've obviously never had a problem like this..
    chad.. I am hopin like heck that I can get the damn trans pan off while the trans is in the car.. remember the 40 is alot smaller than the 46
    later
    sawzall
  20. Django
    Django
    That would be rough, to drop the tranny for the filter! I'd change the modulator anyway then! They're cheap.
    Ok, I think I've messed my terms up. Above when I mentioned the cam and gears, on the drivers side of the tranny, what is that called again? Modulator is on the pass side and runs off vacuum. I don't think Napa would give him "one of those gear thingies on the side". [​IMG] Doh.
  21. Plowboy
    Plowboy
    Ask Dave aka "shifts". He is the god of automatic trannies.
  22. Django
    Django
    It's the GOVERNOR. Man it sucks getting old... [​IMG]
  23. Flatdog
    Flatdog
    Saw,there are severar thing that can do that .If the car moves after sitting it could be a clodded filter,still not good because the debire clodding it is coming from some where .A broken pump gear could do it also usually from cracked flywheel.PS any of you PA boys want a 1950 GMC pickup .You can call me about trans or truck at 973 627 6110 truck is free to some who could it.Spring cleaning at shop.
  24. Mojo
    Mojo
    I made the mistake of changing a trans filter in a TH350 once. It was fine before hand, I figured changing it as preventive maintance would be good. Afterwards, it never shifted the same... I'd go up this certain hill, and stop at the top of it. Well, it would slip really bad for a couple of seconds, and then hit really hard. I'm pretty sure I knocked some dirt loose somewhere, and it was getting caught in the valve body.
  25. shifts
    shifts
    Neither the modulator or governor would cause a no movement problem. You say you have no forward movement, but does it move in rev? Did you notice if it had any howling type noise when it stopped moving? A clogged filter usually makes a sound like a low power stearing pump.Did it move again after sitting for a while? Give me some more info & I can help you out. DAVE
  26. sawzall
    sawzall
    dave.. your name and number are here on my desk.. I was going to call but figured I would try the other stuff first..
    as for reverse.. no no movement there either.. I havent tried to move the car since the problem occured.. I didnt hear anything unusual from the trans prior to the problem occuring..
    again I got the car home till monday night at 10pm and may not get to look at it till wednesday night..
    friday may already be out of the question...
    jeff
  27. sawzall
    sawzall
    just cracked the seal and started drainin the trans.. fluid looks really really clean so far.. no visable leaks from the trans anywhere...
  28. Duck
    Duck
    from Pasco, WA
    Hey Jeff, I am very confident that I DID NOT break your convertible. I hope you get it going soon...
    -Duck
  29. sawzall
    sawzall
    just got the pan down and the filter out heres a pic of whats goin on...
    filter..
  30. sawzall
    sawzall
    thats metal in the previous photo.. and some dirt mixed in for good measure.. heres a shot of the pan.. with the requsite magnets and the layer of metal covering them...
