Hot Rods Cheatin' The Reaper
Discussion in 'The Hokey Ass Message Board' started by Legendlives, Mar 5, 2016.
  1. Chaz
    Chaz
    Nice work!
    Legendlives likes this.
  2. brady1929
    brady1929
    Great job.
  3. Awesome work and well thought out. Looking forward to watching your progress.
  4. Legendlives
    Legendlives
    Went to a swap-meet over the weekend and bought this for a whole $5:
    Which now looks like this:
    And puts bends like this in metal tube. These are aluminium, the top one is 5/8", the bottom 1/2"
    Not strictly part of the project I know, but will help a lot when it comes to making the hard lines..
  5. Legendlives
    Legendlives
    So back with the IRS lower arms, these are now welded together and within a few thou of each other in length.
    I cut the shock tubes from the original arms and smoothed them off ready to weld back in.
    The tubes are welded back in exactly on the weld lines. As there will only be the front shock there will be a bracket which bolts between the shock and the lower hub pivot and takes the rose-joint for the radius arm. More of that later.
    I'm quite happy with the result so far.
    Ron Funkhouser likes this.
  6. Nice work. Rare car too. Does it have the wind out front screen?
  7. Legendlives
    Legendlives
    Yes it does have the wind-out screen, but I've decided to put a 'solid' screen in it.
    dogwalkin likes this.
  8. Nice fab work, that chassis is way stout. I like how you were thinking ahead for running the brake/fuel lines and electrical. Interested to see how you will shorten the half-shafts.
  9. The37Kid
    The37Kid
    Nice project, look forward to more updates. Bob
  10. Legendlives
    Legendlives
    Narrowing the halfshafts:
    I've only got a small-ish lathe to use, so had to come up with an plan that would work without me killing myself with flying shafts!
    So stuck shaft 1 into the lathe and turned these two areas. The left-hand side is turned to 32mm, the centre to 28mm:
    Then hack it into bite size lumps:
    Then turn the short yoke internal diameter to a nice interference fit on 28mm:
    Cut off the 32mm diameter revealing the 28mm internal bore, then press the yoke onto the shaft:
    This took around 10 tons of pressure, so it's a proper interference fit. Not sure I needed to weld it, but I did anyway:
    And here it is next to it's unmodified brother:
    The other shaft will be shortened the same way.
    BradinNC and 1952B3b23 like this.
  11. chessterd5
    chessterd5
    from u.s.a.
    Just awesome! Top-notch work!
  12. Ron Brown
    Ron Brown
    You got MAD SKILLS for sure...I, for one, like the wheel choice for this style car. This body style begs for the strip look. Good stuff here.
    lothiandon1940 and Legendlives like this.
  13. PKap
    PKap
    from Alberta
    I love watching well thought out and fabricated work, especially when it's unique. Will you be running the brakes in board? I was also wondering why you made the driveshaft hoops oval when you are running irs? Are you thinking you may go 9" in the future?
    I like these cars, I just wish I could fit in one!
  14. hasty
    hasty
    Nice work - will be following...
  15. JimmyD3234
    JimmyD3234
    from PA
    nice toy you have - good luck
  16. Legendlives
    Legendlives
    I wanted to make the chassis 'future-proof', so if I do decide to go live axle the structure is already in place.
    And yes, I will be running inboard brakes.
  17. Legendlives
    Legendlives
    Thanks to all for the kind words.
    I've wanted this shape of car for as long as I can remember, and I can't remember the last time I was this enthusiastic about a project.
    I've now managed to secure a manual gearbox (can't say which one as it may upset the purists!) and a pair of wide rear fenders. I'm really looking forward to putting the body on the chassis for the first time which should happen in the net couple of weeks. Rest assured I'll have my camera with me.
    lothiandon1940 likes this.
  18. Ron Brown
    Ron Brown
    I CANT believe you would use THAT gearbox...unbelievable!!!!!
  19. Great work!
  20. Legendlives
    Legendlives
  21. Legendlives
    Legendlives
    BradinNC and saltflats like this.
  22. An amazing chassis!!
  23. Legendlives
    Legendlives
    Whilst the body and chassis are waiting for their matrimony I thought I'd have a dabble at the dashboard:
    It's a stock, steel '38 dash.
    The car was always going to be LHD, so my initial thought was to just fill all of the holes and leave it smooth, ready to add the dials on the 'new' drivers side, but part-way through this process I decided that it would be nice to have a glovebox to put all of the fuses etc into.
    So here we have it. The slots in the bottom are for the wiring to pass through, there is also a slot at the top just in case there is no room to turn the wires.
    It's customary in my builds to use some domestic appliance somewhere in the build (my first drag car had steel from a tumble drier, my 105E Anglia had the engine bulkhead made from washing machine sides and my last car the dash was made from steel taken from an old cooker), so the mods on this one are made from a fire surround :shake:
    I'll make a hinged aluminium door for this to make look more 'factory'
    And the (almost) finished dash:
  24. Legendlives
    Legendlives
    Donation from the boss.
    We've just put a new 'chute onto our Topolino Altered, so the old one is destined for the back of my little Ford :)
  25. Legendlives
    Legendlives
    TFoch likes this.
  26. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Nice project. I've got a '49 three-holer going together. Interesting that the '38 had steel instrument panel (later were Bakelite) and apparently a one-hole grille (later were 2- and 3-hole). Good luck.
  27. DRD57
    DRD57
    Bitchin!
  28. Legendlives
    Legendlives
    Anyone familiar with the Jaguar back axle will know it needs a rear lower tie-bracket to help hold the two wishbone pivots together in higher power applications, so after a bit of head-scratching, cutting, drilling and grinding I ended up with these parts:
    Which after welding together looked like this:
    It's now a 4-function bracket:
    1) It ties the wishbone pivots together and wraps underneath to pick up the bolt-holes on the underside of the pivot brackets.
    2) The large aluminium boss in the middle is the parachute pick-up.
    3) The two circular brackets on either end are for tie-downs to be hooked to (it will undoubtedly spend some of its time on a trailer).
    4) it will provide a strong jacking point.
    The rear panel, parachute brackets, tie-down eyes and underneath reinforcement are made from 5mm steel, the under-bracket is 3mm steel, the 'chute boss is T6061 alloy.
  29. llonning
    llonning
    Looks very well thought out, ought to work perfectly.
  30. Yes, very well planned.
