Autoloc Hoffman Group
Discussion in 'The Hokey Ass Message Board' started by 27 Tall T, Aug 31, 2010.
  1. 27 Tall T
    27 Tall T
    from Butler Pa.
    I did a search of the Hoffman group, and wished I had checked them out before I made a purchase. I bought two linear actuators for my 55 F100. After a couple of months one failed. I called them and got a RA # and returned it for repair. It was out of warrenty because it sat around awhile before it got used. They said expected repair time 1 month. I bought another one so i could get back in service. Called them yesterday , one month later they are backed up at least 1 month. Same story every time I call. Anyone having better luck with customer service? :(
  2. I have had the same issues with them and I live in Oregon. I bought 2 bear claws (big) and popers as well as kits after I paid with a card and told it would be four days
    after two weeks I called and was told there out of stock and wasnt sure when they could ship. Thank god Bobs in Salem worked with me and I didnt have to take it the shorts.
  3. Halfdozen
    Halfdozen
    I spent a bit of time on their website researching Zirgo fans recently. Seems to be a bit of snake oil happening there, with their cfm/ current draw claims.
    Then my email inbox started to fill up with spam from them. Apparently their "unsubscribe" function doesn't work very well...
    Then a friend bought a Helix Mustang II front end kit from them. It's rubbish- ugly mig welds with no penetration, 4.8 grade metric fasteners for lower control arm pivots. Dangerous stuff, IMO.
    Personally, I wouldn't buy a postcard from Hoffman Group.
  4. Lotek_Racing
    Lotek_Racing
    Their stuff is junk from China. I've had nothing but problems from the electrical parts I've bought from them.
    Shawn
  5. I see them advertise in R&C a lot. I also see ads from different company names, but with similar products and similar ad formats. I've always wondered if they were all part of the same company. I also always assumed their stuff was Chinese junk.
  6. And similar addresses. They are snake oil salesmen. Unfortunately there is a HAMBer who works for them. Cheap plastic knock-off import shit.
  7. gearheadbill
    gearheadbill
    100% agree.....totally crapola!!
  8. oldspert
    oldspert
    from Texas
  9. LOWBLAZERO1
    LOWBLAZERO1
    generally a place that runs it's business using many different names is something you should avoid. two that come to mind are:
    -autolok/zirgo/keep it clean wiring/hoffman group
    -aim industries/chassis tech/airbagit.com
    that's my take on it, some may disagree, but generally this is a good rule of thumb.
  10. badshifter
    badshifter
    All of the above, x2. Almost exclusively cheaply made knock off products. Avoid if at all possible.
  11. Their advertisements do have that look of the overly flashy/chintzy. Just too many products to focus on doing anything exceptionally well. I did purchase a Zirgo fan of evilbay several years ago for an off topic rig. I actually like it and it has not failed from driving in many different environments. I did my own relay set-up for it though using a heavy duty relay from a Ford Taurus if memory serves. I run it pusher style, and it still cools quite well.
    I don't know if any of their products will be going on the 1940 though.
  12. Lotek_Racing
    Lotek_Racing
    I've had three replacement igntion switches from them. The plastic rear housing comes loose from the metal front housing and allows the contacts to move out of position. I finally fixed the problem by installing a Cole-Hersee switch. Looks the same but better quality.
    I've been through two of the mechanical brake light switches as well. The contacts seem to burn very easily in them. It was only switching two brake lights. Now it trips a relay that trips the brake lights. Nothing in the package said to use a relay and you would think the contacts would hold up to a pair of 1157 bulbs.
    That being said, the customer service has never been a problem. The faulty units were replaced with no questions.
    Shawn
  13. gimpyshotrods
    gimpyshotrods
    Had a customer bring a set of their solenoids for a shave job on a Riviera. I reluctantly installed them. They lasted just past the warranty period.
  14. prost34
    prost34
    JUNK,with bad customer service,,,
  15. zman
    zman
    from Garner, NC
    Got a Zirgo from Summit not realizing it was Hoffman. Almost made it a month before it burned itself up. I got it because they claimed it was 3000cfm, I wanted a little more airflow over the 1200cfm one that is back on there. Their claim of 3000cfm is complete bullshit. Summit didn't even bother replacing it, they just refunded my money.
  16. kingpins
    kingpins
    complete junk.....shady ass company.....
  17. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Another vote for the junkpile.
    So, let's turn this around.... Spal makes good fans. And as far as door solenoids go, 60's - 80's Mopars are hard to beat.
    Rebel Wire harnesses rule. Bosch makes good stuff.
    Cole-Hersee switches are good, so are NAPA ones.
    Who else makes good stuff that Hoffman offers?
  18. CHOPSHOP
    CHOPSHOP
    from Malden,MA
    you might want to try again- Race (who used to work for Gennie Shifter) works for them now- Im sure he will be turning things around. Glad he will be working somewhere I deal with again.
  19. zman
    zman
    from Garner, NC
    If he can't turn around the quality of their products it won't matter. It's crap right now.... you can be the guinea pig. :eek:
  20. FritzTownFord
    FritzTownFord
    They have a great busine$$ model. Just let other companies spend their money and time to engineer a good product, spend more money establishing a market for it, and then Hoffman just copies it (as cheaply as possible in China). Low overhead = big profits. I think they call that Pirating in other markets.
    Hell, even SEMA won't confront them about the rip-offs because "they are SEMA members". It's a fact.
  21. brigrat
    brigrat
    from Wa.St.
    I also bought a Zergo from Summit, don't need any surprises on the road so how do you tell a Summit Zergo from a Hoffman?
  22. chaos10meter
    chaos10meter
    from PA.
    I purchased numerious items them them on a Merc build and am really satisfied with all the things I ordered.
    Maybe I'm Lucky or something ?
  23. zman
    zman
    from Garner, NC
    They're Hoffman, Summit just carries them...
  24. Hey that's a proven business practice. it has sure worked for Speedway.
    as others move to China we lose big time. I used Bob Drake for 40 years hate to call them now.
    everyone says buy American, as so many trusted names sink to pressure to stay alive competing against cheaper products.
    The good news is, good old American rodders can still fabricate their own stuff using Chinese steel and sub-standard chinese fasteners.
  25. hipkatgreaser
    hipkatgreaser
    Also look out for autohuase on gaybay, that's their store on there also. Not impressed with their actuators.
  26. I was building a truck as a feature build up for a major magazine. They agreed to sponsor the solenoids for the doors. They sent a pair and they wouldn't open the door, not enough pull. The Editor called them and they said send them back and they would send their heavier duty adjustable versions. They wanted the other ones back first. Told them that with the magazine deadline we couldn't wait that long. So they said they would send them COD and refund when they got the others back. They didn't seem any more powerful and they never did refund, even with mutlipls requests. We had a similar issue with a set for a customer, same results and "Customer Service" .
  27. henryj429
    henryj429
    I bought their power window kit. It was so poorly made that I didn't even install it. I did get my money back, but it cost me round-trip shipping.
  28. j.r. Nice
    j.r. Nice
    So glad I found this thread. My AUTOLOC EXPERIENCE
    Last year I bought a set of linear actuators for a tilt-nose project. They sat around for a while, because of other projects. I finally installed them. They worked several months but the nose would bind up during the close cycle. I assumed it was me and the flimsy fiberglass.
    While I was blowing it apart to final paint/detail , one of the actuators fell apart. Bearing disintegrated. Called them and was in their hell-on-hold que for a total of an hour. Finally got thru. Bottom line, no repair parts, no service, and they blew-off the 1 year warranty because I was over 2 weeks. They maligned the $1500+ I had spent with them
    I ordered 2 similar actuators from an Ebay seller. Same ones except less than 1/3 the price ($56 vs $199). If you are gonna get Chinese crap, it's only fair to pay Chinese crap prices.
    As I was inspecting the old ones, I noticed they gave me a mis-matched set.
    New ones installed and work perfectly and there is NO binding. (they are sequentially numbered)
    Also, their relays (motor controllers) wouldnt support the load. Another waste.
    I have their electric window motors in another car. They were a bitch to install because they required significant modification to make them work.
  29. So when are Brian Brennan at Street Rodder and Rob Fortier at R&C going to tell this (group of) companies ... "hey, we sure like your advertising dollars, but your products are crap and we can't, in good conscience, foist them on our readers anymore. Get your act together, and we'll reconsider." We all stay on top of the kind of shit on the HAMB, but there are a lot of guys -- and shops -- that don't. Just as the HAMB has become our advocate, the mass hot rod media should serve everyone.
    Excuse the rant, we gotta look out for our brothers and sisters.
  30. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Yeah, I think the magazines owe it to the readers to weed out the rubbish. Someone else will advertise in that space, probably better quality.
