6 Volt To 12 Volt Conversion
Discussion in 'The Hokey Ass Message Board' started by 4T4DR, Aug 20, 2006.
  1. 4T4DR
    4T4DR
    :) 6 VOLT TO 12 VOLT CONVERSION:
    Could someone please tell me the basics to changing from a 6 volt system to a 12 volt system. I recently purchased a 48 chevy truck which will need to be switched until I fully replace the electrical system and the drive train.
  2. Alienbaby17
    Alienbaby17
    from Mars
    My best advice would be to check out the booklet by Randy Rundle. He operates 5th avenue auto electric and wrote the book- it's very helpful outside of the obvious stuff like change the battery, install an alternator, and change the bulbs....
    Jay
  3. Greazzy13
    Greazzy13
    I just did it with a 1951 Packard. I pulled out ALL the old wiring. DONT throw it away. You never know when you have to refer back. But I went with a 12 circuit wiring harness from Painless. Replaced headlights, taillight bulbs, new dash bulbs, new ignition switch, GM alternator with internal voltage regulator, 12v coil,...The wiring harness replaced the rest. I did use a new fuel, oil pressure, temp, and tach, which the wiring harness had wires for. All in all the conversion cost less than $500. I heartell you can have generators rebuilt for 12 volt. I reused the same starter, plugs, and wires. Good luck.
  4. 4T4DR
    4T4DR
    Thanks for the help open to more also.
  5. Kustomz
    Kustomz
  6. Chebby belair
    Chebby belair
    from Australia
  7. 53DRIVER
    53DRIVER
    from TA CO MA
  8. 40Standard
    40Standard
    from Indy
    I'd swap the generator for an alt. 12 volt battery and light bulbs. borrow your father in law's wiring book on gauge conversion
  9. spin_packard
    spin_packard
    What type of GM 12V alternator should I used to make a conversion from genarator to alternator on a 1951 Packard.
    Any suggestions will be appreciated.
    Thanks guys.
    SpinAuto Group
  10. belair
    belair
    1. H.A.M.B. Chapel
    Just did this with my 48 Chevy. BUY A NEW HARNESS. Mine is disintegrating, but I'm using it for a little while. I went with a one wire alt. from one of the mail order biggies. Easy as pie.
  11. i would use just a normal 3 wire internal regulated alternator..GM made millions of them , you could probably find a good used one. of course , you will have to make a mounting bracket for it , but that shouldn't be too hard if you have access to metal working equipment
  12. gonzo2424
    gonzo2424
    Looking into converting my 54 Chev to 12 volt. Might buy the NCA kit so im not driving around looking for every bulb if someone doesnt have it. Do yall think it is even all that important to convert?
  13. gonzo2424
    gonzo2424
    bump question
  14. jetmek
    jetmek
    you can use the stock gauges...go to napa and buy a p/n IR-1 put in the pwr feed to the gauges. it has points that cycle like a flasher so the averge output is 6v. the rest is pretty simple.
