Got my drop axle from Sid and installed it on my 62.... Got he disc kit from speedway and am having problems with too much slack in there with it tightened up... I added 2 extra washers on the driver side and finally got it without any slack. Driver side I added 4 washers total and it still had slack in the rotor. Only I didn't do was change out the race because the rotor already had them installed. Any help? Posted using the Full Custom H.A.M.B. App!
Thanks Dave!!! Sid got with me and let me know the issue... he gave me all the part numbers to change it up and get it going.
Here's the problem... The kit uses 73-93 Ford Rotors... the rotors already have races installed, but the kit comes with new ones.... So you need to either install the new races and use the supplied bearings or purchase 11810 outer bearing LM11949 and use the already installed race.
