Auctions
39 Ford series 60 PU hot rod project
Discussion in 'Cars For Sale' started by knuck39, Sep 18, 2014.
  1. knuck39
    knuck39
    from nor cal
    City: Chico
    State: California
    Price: 5000.00
    39 Ford Series 60 hot rod project...I've been working off and on on this for the past 6yrs and since I am not getting any younger,I am going to pass it on to someone that has more time to finish this then I do...The hard work is done...
    Solid cab and bed..as it always been in California and Idaho..currently has CA title in my name on non-opp...
    GM A-Arm front suspension with rack and pinion+disc brakes..84 Iroc Z 305 motor,700R4 and disc brake 3:42 posi...Driveline had 78k on it all...motor is currently set-up with an edelbrock semi high rise with a small holley 4 barrel..I also have the complete TPI with harness and computer if you'd rather go down that road...exhaust is run to right behind the rear end...needs wiring,tilt column which comes with it installed and coupled to the rack,and brakes bled and cooling system completed to run(had that already done but needs to be bled out again)...Nice winter project.$5500/offer..530-230-3073/Rick,.or knuck39atyahoo...
  2. knuck39
    knuck39
    from nor cal
  3. knuck39
    knuck39
    from nor cal
  4. knuck39
    knuck39
    from nor cal
  5. knuck39
    knuck39
    from nor cal
    bump....$5500
  6. knuck39
    knuck39
    from nor cal
  7. knuck39
    knuck39
    from nor cal
  8. knuck39
    knuck39
    from nor cal
    the hard work is done...easy winter project....$4600.00
  9. knuck39
    knuck39
    from nor cal
    BUMP....$4500.....
  10. knuck39
    knuck39
    from nor cal
  11. knuck39
    knuck39
    from nor cal
