I have tried Isky, Clay Smith, and the regulars. I want a .500 lift at the valve solid lifter camshaft. Does anybody have a good lead on a company who sells these? I'm kinda getting lost in the shuffle with the afformentioned guys. Most are trying to sell me a hydraulic, Just won't do for me. Thank you, Tim
Any real cam shop with a cam grinder will grind any cam you want. Are you telling us that Isky refused to grind you a cam ? Clay Smith also ? If you don't have a clue what grind you want, then I can understand why they would just say no. If you are a motor builder and know what you want, they will grind you a cam. Remember there are no shelf cams for the Hemi any more. If you are building a 51-54 no one makes those, you must have your core reground or upgrade to the 55 & up style
Try Donnie Johansen at Contreeras Cams. He's here on the HAMB too. Mart3406 --------------- Donnie Johansen Contreras Camshafts Shop phone...909-597-5950 Chino, California. ========================
Thanks for the advice and the point in the right direction. I'll try again tomorrow. Donnie will be a nice change to actually talk to a Grinder. Somebody who uses what they make. While I am not a pro engine builder I have screwed together and keep together plenty of high horsepower tight winding powerplants. I'm pretty sure I know what I want, maybe I just got the "new" help. I need .33 lift at the lobe to give me .50 lift at a 1.5 ratio rocker on solids. I don't want hydraulics I wanna hear 'em work. Tim
