302 on 3 speed tranny?will it work?
Discussion in 'The Hokey Ass Message Board' started by kustumizer, Nov 23, 2003.
  1. kustumizer
    kustumizer
    from Alton,NH
    I have a 68 302 and i have a 62 comet. Would the 302 bolt onto the stock 3 speed tranny. What should i use for motor mounts since the car is unibody? Thanks Nate
  2. AnimalAin
    AnimalAin
    Not sure which transmission you have...... The 302 will bolt to the toploader three speed using all factory parts. The three speed that came with your early six is probably not a good choice. The little Falcons and Comets from the early years can get a V8 with parts from the slightly later ones ('63-65). Several of the outfits that supply restoration parts are sure to have this stuff at a reasonable price.
  3. If your car is original, and it has either the 6 or the early 260, then, no it wont. The 6 trans bell housing is too small, the 8 is a 5 bolt block, Your 68 motor takes a 6 bolt bell housing. The early Falcon/ Comet 3 spd is a POS anyway. Put a toploader or T-10 4 speed. They go around 300 bucks, I've bought them for less. DRR
  4. AHotRod
    AHotRod
    Your best bet is to get a bellhousing and trans to fit the engine, and stick in the hole.
  5. Oh, I forgot about the mounts..The V8 cars have a 3 piece mount that is all bolt on, no hack and splice. Only for the small block though. There are outfits that make them for big blocks as well. All the Falcon Repro joints sell them, I have some, or go on egay. [​IMG]
  6. kustumizer
    kustumizer
    from Alton,NH
    Koool thanks guys!
  7. burndup
    burndup
    My '69 mustang came stock with a 302 and a 3-spd
  8. Nick32vic
    Nick32vic
    I doubt im of any help, but i put some late model ford ranger 3spd w/overdrive on my 68 302
  9. du$ty
    du$ty
    maybe a maverick...some of those later sycro 3spds are pretty good.id say do some measuring.if its too much work .. fuck it put in a t5.
