3 wire alternator feedback car won’t shut off with key
Discussion in 'The Hokey Ass Message Board' started by WisT, Aug 17, 2009.
  1. WisT
    WisT
    A big Thank you to H.A.M.B. and its members for the help in solving this problem. I spent a fair amount of time searching the board to figure this out and had a lot of information to sift through. I’m hoping this post can help others (especially with a part number).
    I recently finished building a T-bucket and had the problem of the alternator feeding back to the ignition. I used a painless 8 circuit harness but used a “tractor” ignition switch along with a push button starter switch. The painless diagrams don’t account for this setup and as I understand it, the way I wired it, the alternator excitor wire is feeding back juice to the coil wire through the “ign.” terminal on the switch. I read about using a diode on the excitor wire and felt this was probably the best way to go. After going to Radio Shack without a specific P/N or specs I called Painless and they gave me the Radio Shack part number 276-1661 this is a 6A 50V rectifier diode ($2.49/pk of 4). I wired it up as shown and it works perfect, its charging and I can shut er’ off.
    Thanks again H.A.M.B.
  2. squirrel
    Thanks for the feedback! Especially since the GM 10-SI alternator is required equipment in every traditional rod....at least it looks that way.....
    (yes I have one on my 55)
  3. saltracer219
    saltracer219
    Delco used to have a resistor diode kit available to fix this problem, but I don't think that it has been available for quite a few years. Your fix looks like a good one, you might think about putting a piece of shrink tube over the diode and connector.
  4. 31aBoy
    31aBoy
    Just used this thread to my advantage today! Thanks!!
  5. fordor41
    fordor41
    I had a GM alt., single wire, built for my Ford. Went to parts store and bought a spare int. reg to install in a new one,if needed, on the road.
  6. spiffy1937
    spiffy1937
    from Florida
    deucemac likes this.
  7. V8 Bob
    V8 Bob
    Installing a #194 or similar dash light in series with the #1 excitor wire will also prevent feedback, and is what GM used for many years. They usually ran a diode parallel with the bulb in case of burnout.
    The link below has a wealth of electrical info, including the very popular 10/12 SI alternators.
    http://www.madelectrical.com/index.shtml
  8. Engine-Ear
    Engine-Ear
    Alliance Vendor
    Very good info.
    I had a lot of people think I was nuts with the light bulb on my car...but it worked!
  9. chopper cliff
    chopper cliff
    from lodi ca
    Use one wire Delco instead, self exciting and doesn't need a diode, but the receptecle is still available from an Auto Electric supply house (they also rebuild starters, alt's and gen's) and a good one can modify exsisting parts for special application, sometimes there parts are cheaper than most Auto parts suppliers. been using them on my Fords since they came out, never had a problem
  10. Inked Monkey
    Inked Monkey
    Such an old thread but soo useful! Worked like a charm. I love the HAMB
  11. ford495051
    ford495051
    How simple. Worked like a charm. Cut the exciter wire at the fuse box and hooked it to the accessory side of the ignition switch. No more feedback. I fussed over this problem for days before reading the solution. Thanks HAMB
  12. stude 283
    stude 283
    Hey thanks for bringing this old thread up and reminding me! Heading to RS tomorrow for a pack for my 1951 pontiac and 460 international tractor.
  13. This info sure takes the mystery out of this setup for everyone.
  14. Jasper6120
    Jasper6120
    from Australia
    The Hamb really is a one stop shop for all the best advice. I had the exact same problem and was trawling all over the internet. Stopped by the Hamb and had my solution in the first post I checked. Ten points.
  15. Had the same problem in an OT car with newer Delco alternator. Turned out the the charging light wasn't working due to a bad connection (oxide) at the bulb. Fixed that and I could shut off the engine with the key again... instead of pulling the ignition wire from the coil.:)
    I ended up putting a diode in the system anyway, just in case the connection would go bad again.
  16. Jasper6120
    Jasper6120
    from Australia
    Wiring up the exciter to the accessories tab on the ignition switch works a charm. Question though; since there will be some kind of feed back from the coil when the accessories are on, would it be a good precautionary measure to install a diode over the exciter line anyway? Just to save a little more juice?
  17. gimpyshotrods
    gimpyshotrods
    I always use the IGN terminal, and run a diode.
  18. trollst
    trollst
    The exciter wire, (white one) works like this, when the key is switched on, it tells the alternator the ign switch is live and ready. Current flows to the alternator, tells the regulator it's ready to accept a charge, start engine, power flows the opposite direction back to the switch. The ign switch inside is separated from the run side, meaning acc is it's own circuit, when switched off, the acc side is dead and doesn't allow current to flow through the switch. If you hook the exciter wire to the run side, the engine will run on after shutting the ign switch off because it'll bypass inside the switch and not shut off. Clear as mud?
  19. Jasper6120
    Jasper6120
    from Australia
    Montana1 and scrap metal 48 like this.
  20. gimpyshotrods
    gimpyshotrods
