Projects 29 Model A Tudor, lots of fab from the ground up
Discussion in 'The Hokey Ass Message Board' started by smitty29, Feb 21, 2013.
  1. smitty29
    smitty29
    from Illinois
    Started with this
    Building the frame with split bones
    Body back on
    fitting the engine in
    radiator mounts
    Ill be back with some serious metal shaping
  2. twenty8tudor
    twenty8tudor
    from Ohio
    looks like a pretty solid body to start with! good luck with the build
  3. Boyd Who
    Boyd Who
  4. smitty29
    smitty29
    from Illinois
    replacement panels fit like shit. Hand made now
  5. smitty29
    smitty29
    from Illinois
    Thanks guys, yeah the body was in alright shape. Some rot to fix but good lines and worthy!
  6. smitty29
    smitty29
    from Illinois
    Time for a floor and trans tunnel. Hand made. Paying homage to the old time metal workers. hand shrunk sheet metal with a tucking fork and english wheel.
    Buck
    Tuck shrinking and wheeling
    Time to weld it up
  7. Greaser Bob
    Greaser Bob
    I'm lovin it man!
  8. fiftyv8
    fiftyv8
    from CO & WA
  9. I'll be watching this with interest, makes me wish I was back home working on my 28.
  10. LSR 2909
    LSR 2909
    from Colorado
    Very nice build.
    Are you sure you want solid radiator mounts? I'm not an expert at anything,but Henry put springs under there for a reason.
  11. Bruce A Lyke
    Bruce A Lyke
    nice fab work, subscribed and looking forward to seeing it get built.
  12. kerwinq
    kerwinq
    from Boise, id
  13. Fenders
    Fenders
    Nice fab work !!
    How's the Ackerman on the front end?
  14. brady1929
    brady1929
  15. Iceberg460
    Iceberg460
    Nice work! Can't wait to see more..
  16. Uptown83
    Uptown83
    Your work looks great! You going after rat rod type build?
  17. JEM
    JEM
    Very nice. Just as is, doesn't need a chop. Only quibble I'd have is use of a slushbox, but that's a personal-preference thing...
    Versailles rear axle? Looks like the big old fifty-pound caliper brackets.
  18. smitty29
    smitty29
    from Illinois
    Thanks for the complements guys
    I have isolation mounts for the radiator, just not on there for mock up. I tend to lose loose parts, good eye
  19. smitty29
    smitty29
    from Illinois
    You got it, no chop!
    Right on, on the axle only one I could find wide enough
    Thanks,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
    I know having the tie rod behind the spindle is ideal but it only gets a slight scrub when the steering is at full lock right or left. Won’t be driving like that at 65, just parking lots.<o:p></o:p>
    Thank you
    Going to be a pristine street rod no rust or Farmall parts on this one. The roof will be solid steel and will have working windows and heat and all.
  20. Wow...I'll watch.
  21. smitty29
    smitty29
    from Illinois
    More updates.
    shrinking and stretching
    Ok, now making the actual floor pannels , with a little bead rolling
    Hopefully I will beable to get some more done next week. starting to get really fun.
  22. smitty29
    smitty29
    from Illinois
    got a little more work done on the fire wall. getting the steering stuff sorted out.
  23. banditomerc
    banditomerc
    You make it look easy...keep up the good work..
  24. Shaun1162
    Shaun1162
    Looks like a great build! Going to be awsome when it's done, and you're making good progress...
    One question though, did you make any sort of "ring" to go around the yoke/u-joint? If the U-joint were to fail while you were going down the road the sheet metal cover wouldn't give much protection...
  25. smitty29
    smitty29
    from Illinois
    Thank you guys
    I do have a pair of drive shaft hoops that I made and yes one does shield the U joint. I'll grab a pic on the next update
  26. Nice work. Thank you for showing it!
  27. Nice work, looking good.
  28. I'm loving the tunnel and floor work. Looks good - keep up the good work - should be cool to watch...
    rg
  29. smitty29
    smitty29
    from Illinois
    Got the fire wall done
  30. OLDTGUY
    OLDTGUY
    Nice metal work, Looking Good.
    JJ
