2003 cv ifs into a 1956 ford f100
Discussion in 'The Hokey Ass Message Board' started by s-man56, Mar 2, 2012.
  1. s-man56
    s-man56
    :confused:want to put a 2003 Crown Vic IFS aluminum crossmember in my 56 f100.I know its wide but I want to take 4" out of the middle to shorten it.but I will need to shorten the power steering rack too. has any one done this to there ford f100. (can the power rack be shortened )? thanks for any help,james
  2. sdluck
    sdluck
    Do a search ,its on here
  3. sdluck
    sdluck
    how much different is the front end in width?
  4. Hogger
    Hogger
    from Carvel AB
    Try a Volare mustang 11 or aerostar van will be a lot easier.
  5. s-man56
    s-man56
    the crown vic is about 67 " hub to hub
  6. sdluck
    sdluck
    What is the 56 frt end
  7. sdluck
    sdluck
  8. s-man56
    s-man56
    I have a 2003 crown vic complete crossmember that I got for free so I want to use it if it doesn't cost too much to have it and the power steering rack narrowed. will look for a place that can give me a estimate on narrowing the IFS and go from there , thanks for your input, james.
    the aerostar might be the way I go if its too expensive to use the crown vic
  9. s-man56
    s-man56
    60" is what I was told but when I measured mine from drum surface to drum surface I got 62" thats why I wanted to take 4" out of the crown vic so it would be close to the same width
  10. tlmartin84
    tlmartin84
    from WV
  11. Hnstray
    Hnstray
    from Quincy, IL
    Consider using a rack that is already narrower, such as T-bird or Fox body Mustang.
    With carefull measurements, you could narrow the CV crossmember to the width needed to prevent bumpsteer with the rack you choose.
    Ray
  12. tlmartin84
    tlmartin84
    from WV
    Ford runs 17x8's with 6.25" of backspace and 45mm of offset from the factory on that front end. So this isn't an issue...........
  13. s-man56
    s-man56
    thanks for all the input on the CV Suspension , james
  14. 73RR
    73RR
    You do realize that a build thread with lots of photos is now required...;)
  15. s-man56
    s-man56
    I'm also putting a lincoln mark 8 IRS on my 1956 f100.I bought the already made adapters from Dave Held AT [URL="http://www.truck irs.com. all the info and install pics are on the web site. I changed the bolt pattern from 5 lug 4.25 to 5 lug 4.5 by changing the hub and bearing . mustang cobra hub. the cobra hub matches the crown vic
    which also has the 5 lug 4.5 the lincoln mark 8 irs has a aluminum pumpkin and lower a arm . nice and clean . also matches the crown vic all alum cross member
  16. s-man56
    s-man56
    thanks to all for your advice
