***SOLD*** There has been a lot done to this truck, it's mechanically sound. Modifications that were done to the engine plus the T5 have really brought the 250 to life! Would make a great "shop truck"! Fresh 1968 250 inline 6 (approx. 500 miles) New hei 32/36 Weber progressive 2bbl New 3 & 3 split exhaust manifold New motor mounts Reconditioned Radiator New exhaust from exhaust manifold to tail pipes New 30" glasspacks 1984 Borg Warner T5 transmission Resurfaced flywheel New pilot bearing, clutch disc., pressure plate & throwout bearing New slip yoke New u-joints 1970 C10 rear axle assembly New pinion seal New axle seal 3:73 gear ratio Jeep Wrangler rear coils New angle correcting 1" lowering blocks New shock relocator brackets New adjustable track bar 1985 C10 front crossmember 2.5" dropped spindles 2" dropped springs New shock absorbers 1985 C10 power steering New power steering pump with reservoir New power steering pump brackets 1985 C10 manual disc brakes New proportioning valve 1970's vented rally wheels New tires New door weatherstripping on both sides Clear Arkansas title Much more $7500.00 o.b.o. You can see more pictures in my albums
***SOLD*** Heading to Eastern Pa in the morning to a fellow hamb'er. Thank you walls and thank you h.a.m.b. classifieds.
