For sale 1952 Ford convert!!!!The body is solid w/no rust,rot or dents and is painted in SEM hot rod black.The hood is full of old school louvers and is nosed.The grille is from a 1950 Dodge.Headlights are frenched. The parking lights are possibly from an old Pontiac.Fender skirts are steel Foxcraft overlay type.The floors are very solid and original as well as the trunk floor and spare tire well. The transmission tunnel has been modified to accept the Hydro-Matic trans. Inner rockers do have some tender areas,but are not bad. This vehicle sits on a stock,solid chassis w/the original rear end,steering and front/rear suspension,but has been lowered 2-1/2" up front and 3" in the rear. Tires are(90%) nice, matching 15" polycord real wide-whites mounted on the correct narrow 15" Ford steel rims.This vehicle has a vintage Cadillac engine/trans combo neatly mounted in . A "Fordillac" as they were called. It's 1953 Cadillac 331 V-8 w/the Hydo-Matic auto trans.It was a strong running unit w/no smoke,noises and good oil pressure that came out of a sedan that went high tech.The drive shaft is in place. All the glass is clear, complete and not broken, The windows all roll up/down smooth,correctly.Window frames are in good condition.There is no interior with the car,but all the garnish mouldings are included and in place. Right now the car does not run/drive. 845-797-677six...
